    <title>[Forum Somfy] Suivi de la question: référence condensateur Ipso rts</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F1003954" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: référence condensateur Ipso rts</description>
    <pubDate>Fri, 26 Feb 2016 09:30:45 GMT</pubDate>
    <lastBuildDate>Fri, 26 Feb 2016 09:30:45 GMT</lastBuildDate>
  <title>Réponse de Ands H.</title>
  <dc:creator>Ands H.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Banjour!&lt;br /&gt;(Je ne pas parlais francais.)&lt;br /&gt;Utiliser&lt;br /&gt;90W moteur: 3,3 µF condensateur. &lt;br /&gt;3µF OK.&lt;br /&gt;Utilise un condensateur de haute qualité.&lt;/p&gt;&lt;p&gt;Dans le condensateur d&amp;#39;origine et défectueuse mesurée 1,2μF sont après 10 ans à gauche.&lt;br /&gt;Il a été fabriqué par AV AVX/Arcotronic. Mal qualite. No-No ;)&lt;/p&gt;&lt;p&gt;Ah, I hate google translate. So please excuse a switchover to denglish ;) (german on demand).&lt;/p&gt;&lt;p&gt;You can look up some more original capacitance values in haustechnik-dialog.de &amp;quot;Somfy Rohrmotor öffnen&amp;quot;, on page 2 they have nice fotos for dismantling the older and newer types of tube motors to replace just the condensor, at the end of the end stop sensing gear. Just as an addition to the great video mentioned by cylain here found on youtube.&lt;/p&gt;&lt;p&gt;Mine was somfy Start 6/17 -  6Nm, 90W -&amp;gt; 3,3µF&lt;br /&gt;Examples for other types:&lt;br /&gt;120W , IPSO : 3,6µF and &lt;br /&gt;120W, Somfy oximo 50 RTS 10/17 : 4,5µF&lt;br /&gt;140W (guessed) 5µF&lt;br /&gt;160µF Oxymo 50 5,5µF&lt;/p&gt;&lt;p&gt;Try to loosen the foam and leave the double sided transparent glue film on the condensor. Perhaps sometimes the film swallows all the inscript of capacitance value that has been there. For me it was readible either way.&lt;/p&gt;&lt;p&gt;You seem to be able to use a formula with some linear factor /1,64 (I adjusted this number by some tries to my needs and the values I have found for somfy motors;) :&lt;br /&gt;C_in_µF = NominalPower÷(230^2)/(2*3,14*50)/1,64&lt;/p&gt;&lt;p&gt;If you have high torque in short time rather smaller than the 4min. &amp;quot;short usage time&amp;quot; given on the label, you may use the next higher value available. If you have plenty of torque, like most of us do, rather use a lower value. But always high quality regarding low aging while &amp;quot;stored&amp;quot; under summerly high temperatures.&lt;/p&gt;&lt;p&gt;There are also ready made tables out there.&lt;br /&gt;See e.g. &lt;br /&gt;&lt;a href=&quot;http://www.conseils-store.com/index.php?store=bead_mess&amp;amp;id=64911&quot; rel=&quot;nofollow&quot;&gt;http://www.conseils-store.com/index.php?store=bead_mess&amp;a...&lt;/a&gt;&lt;br /&gt;He talks of some adaptor to save the hassel of crimping a new flat plug on the condensor cable or directly soldering it (with shrinking tube insulation or similar aging resistant insulation of course;), which I did.&lt;/p&gt;&lt;p&gt;Good luck in saving the environment by replacing capacitors ;) !&lt;/p&gt;&lt;p&gt;Andi&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2395193</link>
  <source url="https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2395193" />
  <guid>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2395193</guid>
  <fb20:id>2395193</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/8305759</fb20:author-profile>
  <fb20:author-avatar>https://dimelo-users-production.s3-eu-west-1.amazonaws.com/identity_avatars/0f374088b18effc2/avatar_normal.png?c6832e6</fb20:author-avatar>
  <fb20:question-id>1003954</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;br /&gt;Je dois changer le condensateur de mon moteur (IPSO RTS),&lt;br /&gt;Afin de le commander, quelqu&amp;#39;un peut il me donner la référence?&lt;br /&gt;Je ne sais pas si le condensateur dépend du coupe du moteur, il se met sur une baie de près de 2.2 m de largeur.&lt;br /&gt;merci par avance de votre aide.&lt;br /&gt;bonne journée&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de armand C.</title>
  <dc:creator>armand C.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Sylvain,&lt;br /&gt;Merci pour le lien,&lt;br /&gt;J&amp;#39;avance, j&amp;#39;ai une baie de 2.4 m donc je dois avoir au moins un IPSO 17 17 (qui déjà est sous dimensionné).&lt;br /&gt;Quelle est la référence du condensateur?&lt;br /&gt;merci par avance et bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Sat, 05 Dec 2015 11:47:40 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2265691</link>
  <source url="https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2265691" />
  <guid>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2265691</guid>
  <fb20:id>2265691</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/7878203</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Armand,&lt;br /&gt;Voir ce lien
      &lt;iframe type=&quot;text/html&quot; width=&quot;320&quot; height=&quot;240&quot; src=&quot;//www.youtube.com/embed/srtIn4Ftb98&quot; frameborder=&quot;0&quot; allowfullscreen&gt;&lt;/iframe&gt;
    &lt;/span&gt;
  <pubDate>Thu, 26 Nov 2015 11:41:13 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2250095</link>
  <source url="https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2250095" />
  <guid>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2250095</guid>
  <fb20:id>2250095</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;br /&gt;Merci de votre réponse mais je n&amp;#39;ai pas encore démonté le moteur, ce n&amp;#39;est pas chez moi et je voudrais éviter de devoir immobiliser le moteur car sans moteur on ne peut plus manoeuvrer (même manuellement) le volet.&lt;br /&gt;Merci&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 26 Nov 2015 06:54:08 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2249551</link>
  <source url="https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2249551" />
  <guid>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2249551</guid>
  <fb20:id>2249551</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;br /&gt;Il faut démonter et remplacer le condensateur par un de la même valeur.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 25 Nov 2015 15:06:05 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2248624</link>
  <source url="https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2248624" />
  <guid>https://forum.somfy.fr/questions/1003954-reference-condensateur-ipso-rts/answers/2248624</guid>
  <fb20:id>2248624</fb20:id>
