    <title>[Forum Somfy] Suivi de la question: cannot remove z-wave module from Tahoma</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F1213137" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: cannot remove z-wave module from Tahoma</description>
    <pubDate>Wed, 14 Dec 2016 10:37:36 GMT</pubDate>
    <lastBuildDate>Wed, 14 Dec 2016 10:37:36 GMT</lastBuildDate>
  <title>Réponse de Willem K.</title>
  <dc:creator>Willem K.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;No prospect of a solution/update yet?&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2788255</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2788255" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2788255</guid>
  <fb20:id>2788255</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/7616795</fb20:author-profile>
  <fb20:question-id>1213137</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;I have a problem with a z-wave module and cannot remove it from the Tahoma configuration. I remember there was a button to neglect the module power connection at the removal process, but this button has disappeared although the text field is still there (since last update?) How to proceed?&lt;/p&gt;&lt;/div&gt;
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi Cedric, You wrote &amp;quot;We have a problem to delete an old product (or product created with a problem during the discovery) inside the Usb key&amp;quot;. As far as I can see the product is removed from the key itself, but not from the Somfy server, so it stays visible in the Tahoma.&lt;br /&gt;On the other hand when you try to add a z-wave product like e.g. the Fibaro Wall Plug that is not supported by Somfy (unfortunately), the product IS added to the usb stick but becomes not visible in the Tahoma interface.&lt;br /&gt;So local and remote profile become misaligned.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 14 Nov 2016 09:11:17 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2741427</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2741427" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2741427</guid>
  <fb20:id>2741427</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Ah, thanks Cedric, you&amp;#39;re my man...the product has been removed indeed, and thanks for acknowledging the issue.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 03 Nov 2016 17:05:48 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2727742</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2727742" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2727742</guid>
  <fb20:id>2727742</fb20:id>
  <title>Réponse de Cédric V.</title>
  <dc:creator>Cédric V.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi,&lt;/p&gt;&lt;p&gt;No solution is available at this date.&lt;br /&gt;I remove one product identified, and we are working on a solution.&lt;br /&gt;We have a problem to delete an old product (or product created with a problem during the discovery)  inside the Usb key.&lt;/p&gt;&lt;p&gt;Is it ok?&lt;/p&gt;&lt;p&gt;regards,&lt;/p&gt;&lt;p&gt;Cédric&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 03 Nov 2016 16:57:38 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2727722</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2727722" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2727722</guid>
  <fb20:id>2727722</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/7494686</fb20:author-profile>
  <fb20:author-avatar>https://dimelo-users-production.s3-eu-west-1.amazonaws.com/identity_avatars/55531667b3243370/avatar_normal.png?bb28c87</fb20:author-avatar>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Still no response from Somfy NL nor FR.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 03 Nov 2016 15:52:37 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2727553</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2727553" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2727553</guid>
  <fb20:id>2727553</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;I have contacted Somfy NL again, but no solution yet.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 03 Nov 2016 09:21:31 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2726766</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2726766" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2726766</guid>
  <fb20:id>2726766</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Dear Gladys, thanks for your reaction, but Somfy France did it before. I even had a phonecall with Cedric V beginning 2016. Netherlands can&amp;#39;t do it. Anyway the ui of the Tahoma should contain an option for a forced removal of z-wave elements, in that case these customer contacts will not be necessary.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 02 Nov 2016 09:12:02 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2725286</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2725286" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2725286</guid>
  <fb20:id>2725286</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello,&lt;/p&gt;&lt;p&gt;We are the technical support for french consumers only, so we can&amp;#39;t have an access to the boxes connected abroad.&lt;br /&gt;You should contact your technical support Somfy.&lt;/p&gt;&lt;p&gt;Regards.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 02 Nov 2016 08:46:25 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2725246</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2725246" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2725246</guid>
  <fb20:id>2725246</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Okay, hope it will be earlier. I thought there was an option for a forced removal, but I can&amp;#39;t find it anymore. Anyway it should be implemented.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 01 Nov 2016 17:51:46 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724922</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724922" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724922</guid>
  <fb20:id>2724922</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;ok Willen,&lt;br /&gt;No worries you will have an answer within a week.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 01 Nov 2016 17:49:05 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724920</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724920" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724920</guid>
  <fb20:id>2724920</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;The pin is 0202-4139-1543&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 01 Nov 2016 17:44:41 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724916</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724916" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724916</guid>
  <fb20:id>2724916</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Here on this post.&lt;br /&gt;And you will have a response from the service.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 01 Nov 2016 17:40:11 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724914</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724914" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724914</guid>
  <fb20:id>2724914</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Sorry Sylvain, what do you mean, where should I enter the PIN?&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 01 Nov 2016 17:36:51 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724911</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724911" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724911</guid>
  <fb20:id>2724911</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Good evening,&lt;br /&gt;It will take, you will have a response from the technical service.&lt;br /&gt;Enter the PIN of your box.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 01 Nov 2016 17:32:14 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724907</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724907" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724907</guid>
  <fb20:id>2724907</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;A reset does not change it Philippe. I still can&amp;#39;t remove the module.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 01 Nov 2016 17:19:40 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724889</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724889" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724889</guid>
  <fb20:id>2724889</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi&lt;br /&gt;make a reset of your Tahoma and restart&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 01 Nov 2016 16:42:31 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724850</link>
  <source url="https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724850" />
  <guid>https://forum.somfy.fr/questions/1213137-cannot-remove-z-wave-module-from-tahoma/answers/2724850</guid>
  <fb20:id>2724850</fb20:id>
  <fb20:author-avatar>https://dimelo-users-production.s3.amazonaws.com/identity_avatars/2d2415e2ef7c0c5d/avatar_normal.png?bb28c87</fb20:author-avatar>
