    <title>[Forum Somfy] Suivi de la question: configuration alarme protexiom 600 sur freebox crystal</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F1228120" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: configuration alarme protexiom 600 sur freebox crystal</description>
    <pubDate>Mon, 28 Nov 2016 13:20:18 GMT</pubDate>
    <lastBuildDate>Mon, 28 Nov 2016 13:20:18 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Merci de ce retour !&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2762486</link>
  <source url="https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2762486" />
  <guid>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2762486</guid>
  <fb20:id>2762486</fb20:id>
  <fb20:question-id>1228120</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;malgres l&amp;#39;ouverture des port 80 et 443&lt;/p&gt;&lt;p&gt;je rentre l&amp;#39;adresse ip de l alarme sur l&amp;#39;ordi mais je ne peux acceder a l&amp;#39;interface  alarme&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de gerard B.</title>
  <dc:creator>gerard B.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;merci beaucoup jean luc champion du monde ! cetait bien la solution&lt;/p&gt;&lt;/div&gt;
  <pubDate>Sun, 27 Nov 2016 20:18:29 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2761734</link>
  <source url="https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2761734" />
  <guid>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2761734</guid>
  <fb20:id>2761734</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/7893663</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonsoir&lt;/p&gt;&lt;p&gt;si vous avez changé de box, il faut réinitialiser le module IP.&lt;/p&gt;&lt;p&gt;&lt;a href=&quot;https://www.somfy.fr/support/videos/alarme&quot; rel=&quot;nofollow&quot;&gt;https://www.somfy.fr/support/videos/alarme&lt;/a&gt;&lt;/p&gt;&lt;/div&gt;
  <pubDate>Sun, 27 Nov 2016 17:45:31 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2761600</link>
  <source url="https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2761600" />
  <guid>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2761600</guid>
  <fb20:id>2761600</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;bonjour jean luc merci  pour votre aide &lt;br /&gt;j&amp;#39;ai récupéré l&amp;#39;adresse IP de l&amp;#39;alarme sur le clavier  de celle ci  quand au message d&amp;#39;erreur l&amp;#39;ordi  me dis&lt;br /&gt;des que je rentre l&amp;#39;adresse ip de l&amp;#39;alarme  que le sce ne répond pas ou que les port 80 et 443 ne sont  peut etre pas ouverts  pour info j&amp;#39;avais avant la box sfr  et  cela fonctionnait bien je suis passé chez free voila 2 jour.. cordialement&lt;/p&gt;&lt;/div&gt;
  <pubDate>Sun, 27 Nov 2016 11:09:04 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2761356</link>
  <source url="https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2761356" />
  <guid>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2761356</guid>
  <fb20:id>2761356</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Comment avez-vous récupéré votre adresse IP ? Quel est le message d&amp;#39;erreur ?&lt;/p&gt;&lt;/div&gt;
  <pubDate>Sat, 26 Nov 2016 16:50:04 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2760895</link>
  <source url="https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2760895" />
  <guid>https://forum.somfy.fr/questions/1228120-configuration-alarme-protexiom-600-freebox-crystal/answers/2760895</guid>
  <fb20:id>2760895</fb20:id>
