    <title>[Forum Somfy] Suivi de la question: External blinds loosing configuration after power outage</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F1229362" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: External blinds loosing configuration after power outage</description>
    <pubDate>Fri, 02 Dec 2016 16:21:44 GMT</pubDate>
    <lastBuildDate>Fri, 02 Dec 2016 16:21:44 GMT</lastBuildDate>
  <title>Réponse de Gregor B.</title>
  <dc:creator>Gregor B.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Dear Thomas!&lt;/p&gt;&lt;p&gt;Thank you for your answer! &lt;/p&gt;&lt;p&gt;To clarify: out of 18 blinds practically at every power outage one of few blinds &amp;quot;get messed&amp;quot;. This mean that I can only move this blinds to completelly closed or completelly opened. If I try to steer them to e.g. horisontal position, they open completelly. &lt;/p&gt;&lt;p&gt;The solution I found here is that using Set&amp;amp;Go I readjust the non-working blind by setting Tilting travel. I have all blinds set to 28. When I open Tilting travel for a messed-up blind it shows something like 28456. I manually set it back to 28, confirm and afterwards it Works normally.&lt;/p&gt;&lt;p&gt;I&amp;#39;m really keen on Somfy IO and I would like to purchase some additional devices for lighting (like outdoor lighting put on timer), but absolutelly need to solve the power outage issue...&lt;/p&gt;&lt;p&gt;Thank you in advance and Kind Regards,&lt;br /&gt;Grega&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2770283</link>
  <source url="https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2770283" />
  <guid>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2770283</guid>
  <fb20:id>2770283</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/6723765</fb20:author-profile>
  <fb20:question-id>1229362</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Dear!&lt;/p&gt;&lt;p&gt;I have already reported that I have 18 external blinds with J4 io motors together with Slim Receivers io. Unfortunatelly, after every electricity outage one or more blinds get messed. They lose its &amp;quot;my positions&amp;quot;, so I can only steer them fully open or fully close. Only possibility is that I again program them. This in extremelly annoying and I hardly believe that this is the case.&lt;/p&gt;&lt;p&gt;What are your experiences? Hopefully somebody can help me with some idea? Upgrade? &lt;/p&gt;&lt;p&gt;Kind Regards,&lt;br /&gt;Grega&lt;/p&gt;&lt;/div&gt;
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Good afternoon Gregor,&lt;/p&gt;&lt;p&gt;You said that the J4 motors lose their &amp;quot;My postions&amp;quot; after every electricity outage. Is it the only program that they lose ? &lt;/p&gt;&lt;p&gt;There is no kown problem with Slim Receivers IO or RTS. The answer gave by your installer is not professionnal. There is no difference for the &amp;quot;My position&amp;quot; between RTS and IO. Your installer should contact our technical assistance for professional if they need help. &lt;/p&gt;&lt;p&gt;Best Regards,&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 02 Dec 2016 16:06:19 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2770229</link>
  <source url="https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2770229" />
  <guid>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2770229</guid>
  <fb20:id>2770229</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi!&lt;/p&gt;&lt;p&gt;That&amp;#39;s my problem. They constantly blame IO technology (they told me that I&amp;#39;m still the only one with IO that every body else is using RTS), that it is not so good... They simply gave me Set&amp;amp;Go module that I program them after each power outage as they terribly lack of experiences... &lt;/p&gt;&lt;p&gt;So, is it possible that there is some memory problem with Slim Receivers? Were there any new versions? Is it possible to upgrade or need to be exchanged?&lt;/p&gt;&lt;p&gt;I will appreciate any information.&lt;/p&gt;&lt;p&gt;Kind Regards,&lt;br /&gt;Grega&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 29 Nov 2016 06:53:49 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763673</link>
  <source url="https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763673" />
  <guid>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763673</guid>
  <fb20:id>2763673</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi !&lt;/p&gt;&lt;p&gt;So contact your installer.&lt;br /&gt;They must still be guaranteed.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 29 Nov 2016 04:57:34 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763657</link>
  <source url="https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763657" />
  <guid>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763657</guid>
  <fb20:id>2763657</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi Jean-Luc!&lt;/p&gt;&lt;p&gt;Equippment was installed 2 years ago.&lt;/p&gt;&lt;p&gt;Kind Regards,&lt;br /&gt;Grega&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 28 Nov 2016 18:13:19 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763367</link>
  <source url="https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763367" />
  <guid>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763367</guid>
  <fb20:id>2763367</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi Gregor&lt;/p&gt;&lt;p&gt;How old are your equipment?&lt;br /&gt;There seems to be a memory problem.&lt;/p&gt;&lt;p&gt;Regards&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 28 Nov 2016 17:02:30 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763256</link>
  <source url="https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763256" />
  <guid>https://forum.somfy.fr/questions/1229362-external-blinds-loosing-configuration-after-power-outage/answers/2763256</guid>
  <fb20:id>2763256</fb20:id>
