    <title>[Forum Somfy] Suivi de la question: Problème connexion caméra axis tahoma</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F1249327" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Problème connexion caméra axis tahoma</description>
    <pubDate>Fri, 23 Dec 2016 19:57:00 GMT</pubDate>
    <lastBuildDate>Fri, 23 Dec 2016 19:57:00 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Cette procédure :&lt;/p&gt;&lt;p&gt;How to set the root password To access the Axis product, you must set the password for the default administrator user root. This is done in the Configure Root Password dialog, which opens when the product is accessed for the first time. &lt;/p&gt;&lt;p&gt;To prevent network eavesdropping, the root password can be set via an encrypted HTTPS connection, which requires an HTTPS certificate. HTTPS (Hypertext Transfer Protocol over SSL) is a protocol used to encrypt traffic between web browsers and servers. The HTTPS certificate ensures encrypted exchange of information. See HTTPSonpage47. &lt;/p&gt;&lt;p&gt;The default administrator user name root is permanent and cannot be deleted. If the password for root is lost, the product must be reset to the factory default settings. See Howtoresettofactorydefaultsettingsonpage57. &lt;/p&gt;&lt;p&gt;To set the password via a standard HTTP connection, enter it directly in the dialog. &lt;/p&gt;&lt;p&gt;To set the password via an encrypted HTTPS connection, follow these steps: &lt;/p&gt;&lt;p&gt;   1. Click Use HTTPS. A temporary certificate (valid for one year) is created, enabling encryption of all traffic to and from the product, and the password can now be set securely. &lt;br /&gt;   &lt;br /&gt;   2. Enter a password and then re-enter it to confirm the spelling. &lt;br /&gt;   &lt;br /&gt;   3. Click OK. The password has now been configured.&lt;/p&gt;&lt;p&gt;Set Power Line Frequency &lt;/p&gt;&lt;p&gt;Power line frequency is set the first time the Axis product is accessed and can only be changed from Plain Config (see page57) or by resetting the product to factory default. &lt;/p&gt;&lt;p&gt;Select the power line frequency (50 Hz or 60 Hz) used at the location of the Axis product. Selecting the wrong frequency may cause image flicker if the product is used in fluorescent light environments. &lt;/p&gt;&lt;p&gt;When using 50 Hz, the maximum frame rate is limited to 25 fps. &lt;/p&gt;&lt;p&gt;  Note &lt;/p&gt;&lt;p&gt;Power line frequency varies depending on geographic region. The Americas usually use 60 Hz, whereas most other parts of the world use 50 Hz. Local variations could apply. Always check with the local authorities.&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/1249327-probleme-connexion-camera-axis-tahoma/answers/2805253</link>
  <source url="https://forum.somfy.fr/questions/1249327-probleme-connexion-camera-axis-tahoma/answers/2805253" />
  <guid>https://forum.somfy.fr/questions/1249327-probleme-connexion-camera-axis-tahoma/answers/2805253</guid>
  <fb20:id>2805253</fb20:id>
  <fb20:question-id>1249327</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour&lt;br /&gt;J ai une box tahoma depuis 2011 !&lt;br /&gt;J ai déjà 4 camera axis qui fonctionnent&lt;br /&gt;Je souhaite ajouter une nouvelle caméra axis&lt;br /&gt;Tahoma la détecté bien, je clic, je rentre identifiant root et mot de passe et ensuite il cherche ...et la procédure s arrête...&lt;/p&gt;&lt;p&gt;Qui peux m aider !!!?&lt;/p&gt;&lt;p&gt;Cdt&lt;/p&gt;&lt;p&gt;Modèle axis 3904-R&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de olivier H.</title>
  <dc:creator>olivier H.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonsoir jean Luc&lt;br /&gt;Quelle procédure ???&lt;br /&gt;C est moi qui a défini le mot de passe !&lt;br /&gt;Pouvez me décrire la procédure en qu lignes&lt;br /&gt;(Si il faut je peux faire un reset de la cam)&lt;br /&gt;Merci !&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 23 Dec 2016 18:08:00 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1249327-probleme-connexion-camera-axis-tahoma/answers/2805102</link>
  <source url="https://forum.somfy.fr/questions/1249327-probleme-connexion-camera-axis-tahoma/answers/2805102" />
  <guid>https://forum.somfy.fr/questions/1249327-probleme-connexion-camera-axis-tahoma/answers/2805102</guid>
  <fb20:id>2805102</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/6198905</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonsoir&lt;/p&gt;&lt;p&gt;avez-vous défini le mot de passe selon la procédure?&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 23 Dec 2016 18:00:49 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1249327-probleme-connexion-camera-axis-tahoma/answers/2805085</link>
  <source url="https://forum.somfy.fr/questions/1249327-probleme-connexion-camera-axis-tahoma/answers/2805085" />
  <guid>https://forum.somfy.fr/questions/1249327-probleme-connexion-camera-axis-tahoma/answers/2805085</guid>
  <fb20:id>2805085</fb20:id>
