    <title>[Forum Somfy] Suivi de la question: Support with solus transmitter</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F1403938" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Support with solus transmitter</description>
    <pubDate>Thu, 27 Jul 2017 10:19:57 GMT</pubDate>
    <lastBuildDate>Thu, 27 Jul 2017 10:19:57 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Good Morning Francesco,&lt;/p&gt;&lt;p&gt;When you need to let your finger on the remote control to have a mouvement of your motor that is because the programmation of the motor is&amp;#39;nt finish yet.&lt;/p&gt;&lt;p&gt;Normally it&amp;#39;s not possible to end the programmation with this kind of remote control. Do you have an another kind of remote control or do you have a &amp;quot;PROG&amp;quot; button in the backside of the Solus Transmitter ?&lt;/p&gt;&lt;p&gt;Regards,&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/1403938-support-with-solus-transmitter/answers/3171521</link>
  <source url="https://forum.somfy.fr/questions/1403938-support-with-solus-transmitter/answers/3171521" />
  <guid>https://forum.somfy.fr/questions/1403938-support-with-solus-transmitter/answers/3171521</guid>
  <fb20:id>3171521</fb20:id>
  <fb20:question-id>1403938</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello. &lt;br /&gt;When I press one of my solus transmitter (attached on the wall) it moves the roll-up shutter in the desired direction. &lt;br /&gt;But if I remove the finger from the button it stops.&lt;br /&gt;I&amp;#39;d like to change this behaviour to &amp;quot;move on one click and stop on another click&amp;quot; as my other solus transmitters. &lt;br /&gt;How can I do this?&lt;/p&gt;&lt;/div&gt;
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonsoir,&lt;br /&gt;Vous aurez une réponse du SAV sur ce post, pour une solution à votre problème.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 24 Jul 2017 19:13:40 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1403938-support-with-solus-transmitter/answers/3167261</link>
  <source url="https://forum.somfy.fr/questions/1403938-support-with-solus-transmitter/answers/3167261" />
  <guid>https://forum.somfy.fr/questions/1403938-support-with-solus-transmitter/answers/3167261</guid>
  <fb20:id>3167261</fb20:id>
