    <title>[Forum Somfy] Suivi de la question: Applet IFTTT ne lance pas scénario Tahoma</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F1502904" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Applet IFTTT ne lance pas scénario Tahoma</description>
    <pubDate>Fri, 24 Nov 2017 12:09:33 GMT</pubDate>
    <lastBuildDate>Fri, 24 Nov 2017 12:09:33 GMT</lastBuildDate>
  <title>Réponse de Ulrich C.</title>
  <dc:creator>Ulrich C.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;OK, j&amp;#39;ai trouvé la réponse sur le forum IFTTT tout simplement.&lt;/p&gt;&lt;p&gt;On iOS add to your homescreen&lt;/p&gt;&lt;p&gt;    In the IFTTT app, tap My Applets&lt;br /&gt;    Then tap Settings in the top left&lt;br /&gt;    Select widgets&lt;br /&gt;    Select the Applet widget you&amp;#39;d like to add to your homescreen&lt;br /&gt;    Tap to Add the Applet as a homescreen icon&lt;br /&gt;    Follow the step-by-step directions on screen&lt;/p&gt;&lt;p&gt;On Android add to your homescreen&lt;/p&gt;&lt;p&gt;    Long press any empty place on your homescreen&lt;br /&gt;    Select Widgets&lt;br /&gt;    Locate the IFTTT app and drag it to your homescreen&lt;br /&gt;    Select a specific Applet widget you want to add&lt;br /&gt;    Boom, your Applet widget is ready to be pressed&lt;/p&gt;&lt;p&gt;Ca fonctionne bien.&lt;br /&gt;Merci.&lt;br /&gt;@+&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3367795</link>
  <source url="https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3367795" />
  <guid>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3367795</guid>
  <fb20:id>3367795</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/9684037</fb20:author-profile>
  <fb20:question-id>1502904</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;br /&gt;Je suis très embêté de poser cette question, mais j&amp;#39;ai suivi les étapes de création d&amp;#39;applet sur IFTTT, mais celles-ci ne lancent pas mes scénarios (ouverture/fermeture de volets) qui fonctionnent très bien via l&amp;#39;application tahomalink. &lt;br /&gt;J&amp;#39;ai créé des applets type &amp;quot;button&amp;quot; et type &amp;quot;Date Time&amp;quot; et rien n&amp;#39;y fait.&lt;br /&gt;Auriez-vous des pistes ? Elles sont bien activées et pourtant le &amp;quot;check now&amp;quot; n&amp;#39;a aucun effet. Y a t il une action a faire coté tahoma box ?&lt;/p&gt;&lt;p&gt;Merci d&amp;#39;avance,&lt;br /&gt;Ulrich&lt;/p&gt;&lt;/div&gt;
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonsoir,&lt;/p&gt;&lt;p&gt;Merci pour votre réponse. En effet, j&amp;#39;ai regardé dans mon téléphone. Je suis sous Android 5.0.1 (Galaxy S4), et je ne vois pas comment ajouter un raccourci au widget ou bien envoyer vers un écran d&amp;#39;accueil. &lt;br /&gt;En sélection le widget, j&amp;#39;arrive sur son paramétrage, et rien ne se passe si je laisse mon doigt sur le widget.&lt;br /&gt;Je ferais le test avec le téléphone de ma femme plus récent ce soir.&lt;/p&gt;&lt;p&gt;Ulrich&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 23 Nov 2017 17:40:36 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3366546</link>
  <source url="https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3366546" />
  <guid>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3366546</guid>
  <enclosure length="80805" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/f700eed30b6e007c/screenshot_2017_11_23_18_33_21_original.png?c6832e6" type="image/png" />
  <fb20:id>3366546</fb20:id>
  <title>Réponse de jacky L.</title>
  <dc:creator>jacky L.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;bonjour&lt;br /&gt;merci pour l&amp;#39;astuce ....&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 23 Nov 2017 12:31:15 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3365694</link>
  <source url="https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3365694" />
  <guid>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3365694</guid>
  <fb20:id>3365694</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/7482242</fb20:author-profile>
  <fb20:author-avatar>https://dimelo-users-production.s3.amazonaws.com/identity_avatars/2ef9e906f317951f/avatar_normal.png?c6832e6</fb20:author-avatar>
  <title>Réponse de Pierre M.</title>
  <dc:creator>Pierre M.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Pour créer un bouton sous iOs, c&amp;#39;est simple, je ne connais pas Android...&lt;/p&gt;&lt;p&gt;Dans ton apllets,&lt;br /&gt;tu vas sur Widget settings,&lt;br /&gt;en bas, tu as Homescreen icon et tu suis la mamip.&lt;br /&gt;cela ajoute un icon sur ton ecran.&lt;/p&gt;&lt;p&gt;top&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 23 Nov 2017 10:48:49 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3365414</link>
  <source url="https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3365414" />
  <guid>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3365414</guid>
  <enclosure length="237478" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/fb0471a3fb39c0de/image_1_original.jpg?c6832e6" type="image/jpeg" />
<enclosure length="125701" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/d064ffbeb79fe6e7/image_1_original.jpg?c6832e6" type="image/jpeg" />
  <fb20:id>3365414</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/8565474</fb20:author-profile>
  <fb20:author-avatar>https://dimelo-users-production.s3-eu-west-1.amazonaws.com/identity_avatars/84370edba637dd37/avatar_normal.png?c6832e6</fb20:author-avatar>
  <title>Réponse de Yannick M.</title>
  <dc:creator>Yannick M.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Check now ne lance pas votre action, c’est normal&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 22 Nov 2017 20:26:51 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3364588</link>
  <source url="https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3364588" />
  <guid>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3364588</guid>
  <fb20:id>3364588</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/7612080</fb20:author-profile>
  <fb20:author-avatar>https://dimelo-users-production.s3.amazonaws.com/identity_avatars/877eec37f133076a/avatar_normal.png?c6832e6</fb20:author-avatar>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonsoir,&lt;br /&gt;De mon côté pas de soucis, ifttt fonctionne correctement. Comment avez vous créé des boutons et sur quel OS ?&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 22 Nov 2017 19:00:39 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3364473</link>
  <source url="https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3364473" />
  <guid>https://forum.somfy.fr/questions/1502904-applet-ifttt-lance-scenario-tahoma/answers/3364473</guid>
  <fb20:id>3364473</fb20:id>
