    <title>[Forum Somfy] Suivi de la question: Problem with Somfy Smoke Detector IO</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F1894157" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Problem with Somfy Smoke Detector IO</description>
    <pubDate>Mon, 30 Dec 2024 10:51:25 GMT</pubDate>
    <lastBuildDate>Mon, 30 Dec 2024 10:51:25 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Steven,&lt;br /&gt;Le detecteur de fumée IO n&amp;#39;est pas compatible avec le kit de connectivtié (aucun capteur n&amp;#39;est compatible avec le kit de connectivité)&lt;br /&gt;Bonne journée&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8950034</link>
  <source url="https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8950034" />
  <guid>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8950034</guid>
  <fb20:id>8950034</fb20:id>
  <fb20:question-id>1894157</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello,&lt;/p&gt;&lt;p&gt;I&amp;#39;m having a problem with one of my 2 Smoke detectors.  It doesn&amp;#39;t seem able to keep a connection to the Tahoma box.  This seems to be a regular problem, I&amp;#39;ve seen on the forums and I&amp;#39;ve tried all the suggested manipulations.  &lt;/p&gt;&lt;p&gt;The device constantly shows no battery, even after I&amp;#39;ve bought brand new batteries for it and changed them.&lt;/p&gt;&lt;p&gt;(See attached image)&lt;/p&gt;&lt;p&gt;I tried removing the device from tahoma and resetting it (holding the test button for 20 seconds) and then re-adding it to tahoma and I get the following error:&lt;/p&gt;&lt;p&gt;(See attached image)&lt;/p&gt;&lt;p&gt;The distance between the detector and the tahoma is less than 10 meters and it&amp;#39;s closer than the upstairs detector that is working perfectly.&lt;/p&gt;&lt;p&gt;Any suggestions on how to fix this?&lt;/p&gt;&lt;p&gt;Thanks,&lt;/p&gt;&lt;p&gt;Adam&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de Steven S.</title>
  <dc:creator>Steven S.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour&lt;/p&gt;&lt;p&gt;J’ai acquis le  connectivité kit que j’ai installé sans problème&lt;/p&gt;&lt;p&gt;Puis j’ai acheté le smoke détector Io mais impossible a installé&lt;/p&gt;&lt;p&gt;Il n’est pas proposé dans les objets du connectivité kit&lt;/p&gt;&lt;p&gt;Merci de m’indiquer la procédure à suivre &lt;/p&gt;&lt;p&gt;Connectivity kit 1209 3345 &lt;/p&gt;&lt;p&gt;Cdt&lt;/p&gt;&lt;/div&gt;
  <pubDate>Sun, 29 Dec 2024 13:33:01 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8949635</link>
  <source url="https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8949635" />
  <guid>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8949635</guid>
  <fb20:id>8949635</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/18868149</fb20:author-profile>
  <title>Réponse de Mihai M.</title>
  <dc:creator>Mihai M.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Thanks for the info. Is there any way thos detector can be repaired by resetting it other way than pressing the test button? maybe shortcircuiting any pins on the micro-controller from the mainboard?&lt;br /&gt;I tested to see if it detects smoke without adding it to Tahoma, and it detects the smoke successfully. So, apart from the reset which doesn&amp;#39;t work, the detectors function properly.&lt;br /&gt;Thank you,&lt;br /&gt;Mihai&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 08 Aug 2024 06:44:00 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8802344</link>
  <source url="https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8802344" />
  <guid>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8802344</guid>
  <fb20:id>8802344</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/19951063</fb20:author-profile>
  <fb20:author-avatar>https://dimelo-users-production.s3.amazonaws.com/identity_avatars/9aa8bd3645f41c61/avatar_normal.png?bb28c87</fb20:author-avatar>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Thanks for the info. is there any way this detector can be repaired? I tested to see if it&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 08 Aug 2024 06:40:37 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8802341</link>
  <source url="https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8802341" />
  <guid>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8802341</guid>
  <fb20:id>8802341</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;After reset ( 3bips and another 3 bips) le led stay blinking ever 2 sec, to notify it&amp;#39;s in programmation mode.&lt;br /&gt;If it doesn&amp;#39;t, it seem&amp;#39;s like the detector is defect.&lt;br /&gt;have a nice day&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 07 Aug 2024 13:18:02 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8801722</link>
  <source url="https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8801722" />
  <guid>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8801722</guid>
  <fb20:id>8801722</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Nicolas, I have already replaced the CR123 with a new one. &lt;br /&gt;What shoud be the bahaviour of the led when the detector is reset? It should blink differently? &lt;br /&gt;Thanks&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 07 Aug 2024 11:12:52 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8801503</link>
  <source url="https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8801503" />
  <guid>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8801503</guid>
  <fb20:id>8801503</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Mihai,&lt;br /&gt;you have to change the CR123 battery and add again in tahoma.&lt;br /&gt;have a nice day.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 07 Aug 2024 10:55:10 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8801456</link>
  <source url="https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8801456" />
  <guid>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8801456</guid>
  <fb20:id>8801456</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;I have the exact same issue. I deleted the smoke detector from Tahoma and I tried to add it again. Before adding it I tried to reset the detector to factory default, but there is nowhere in the documentation mentioned how the led should blink after the device is reset. I tried holding the test button until I heard 6 beeps (3 bips, then another 3 bips), then tried to add it to Tahoma, but Tahoma says there is no smoke detector found.&lt;/p&gt;&lt;p&gt;How can I properly reset this to factory defaults?&lt;br /&gt;thanks,&lt;br /&gt;Mihai&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 06 Aug 2024 21:12:27 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8800727</link>
  <source url="https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8800727" />
  <guid>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/8800727</guid>
  <fb20:id>8800727</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello Adam,&lt;/p&gt;&lt;p&gt;Regarding your problem and the différent manipulations that you have tried to fix it, your smoke detector seems to be defective.&lt;/p&gt;&lt;p&gt;To manage the replacment of it I need some of your personnal informations that is why i just sent you an email.&lt;/p&gt;&lt;p&gt;Regards,&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 13 Feb 2019 12:45:44 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/4346641</link>
  <source url="https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/4346641" />
  <guid>https://forum.somfy.fr/questions/1894157-problem-with-somfy-smoke-detector-io/answers/4346641</guid>
  <fb20:id>4346641</fb20:id>
