    <title>[Forum Somfy] Suivi de la question: Tahoma DIN Rail installation</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F2445225" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Tahoma DIN Rail installation</description>
    <pubDate>Fri, 30 Oct 2020 11:01:16 GMT</pubDate>
    <lastBuildDate>Fri, 30 Oct 2020 11:01:16 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello gregor,&lt;br /&gt;there is no difference between sunis wirefree IO and sunis wirefree IO 2.&lt;br /&gt;only hardware update.&lt;br /&gt;it&amp;#39;s not possible on tahomapad.&lt;br /&gt;best regards.&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/6052052</link>
  <source url="https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/6052052" />
  <guid>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/6052052</guid>
  <fb20:id>6052052</fb20:id>
  <fb20:question-id>2445225</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello!&lt;/p&gt;&lt;p&gt;I decided to upgrade my &amp;quot;old&amp;quot; TahomaPad and I choose Tahoma DIN Rail instead of Tahoma Box (as I can install it in the cabinet). I have few questions:&lt;/p&gt;&lt;p&gt;1. It is not clear if Tahoma DIN Rail has WiFi included inside Central Unit or it has to be a separate communication module (similar to e.g. io Module which I would need, too)? &lt;/p&gt;&lt;p&gt;2. Can Tahoma DIN Rail work in offline mode (when there is no internet connection)?&lt;/p&gt;&lt;p&gt;3. Can I install Tahoma DIN Rail in a steel cabinet? Or is there an external antenna available?&lt;/p&gt;&lt;p&gt;4. Can I connect to IP videophone like Doorbird? Any experiences with some other IP videophones?&lt;/p&gt;&lt;p&gt;5. Do I use Tahoma DIN Rail exactly the same as Tahoma Box (same app, same configuration)?&lt;/p&gt;&lt;p&gt;6. Is it possible to use Somfy Indoor Camera together with Tahoma DIN Rail? E.g. in order to check camera from Tahoma app?&lt;/p&gt;&lt;p&gt;7. Is it possible to use Sunset/Sunrise in scenarios with some time offset, e.g. half an hour after sunset?&lt;/p&gt;&lt;p&gt;8. I&amp;#39;m an electrical engineer with good computer skills. Can I install and configure Tahoma DIN Rail on my own like I did TahomaPad some years ago?&lt;/p&gt;&lt;p&gt;Thank you and kind regards,&lt;br /&gt;Grega&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de Gregor B.</title>
  <dc:creator>Gregor B.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello!&lt;/p&gt;&lt;p&gt;One more question, please: I plan to install outdoor sun sensor. What is the difference between &amp;quot;Sunis Wirefree IO&amp;quot; and &amp;quot;Sunis Wirefree 2 IO&amp;quot; sensors?&lt;/p&gt;&lt;p&gt;On TahomaPad I could only set one treshold which triggered two scenarios - 1st when sun intensity was above treshold, and 2nd when suw way below treshold. It would be nice tho have at least two tresholds?&lt;/p&gt;&lt;p&gt;Best regards,&lt;br /&gt;Grega&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 27 Oct 2020 08:07:52 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/6042555</link>
  <source url="https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/6042555" />
  <guid>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/6042555</guid>
  <fb20:id>6042555</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/6723765</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello Gregor,&lt;br /&gt;your scenarios can&amp;#39;t be transfered to the tahoma rail din.&lt;br /&gt;You have to recreate it. &lt;br /&gt;No on tahoma you can&amp;#39;t adjust your upper and lower settings, you still have to use your set&amp;amp;go.&lt;br /&gt;You may have to registrer it on french server i think it was more easy to contact us if you have problems. but the interface was in french.&lt;br /&gt;Have a nice day&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 10 Sep 2020 10:18:05 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/5913693</link>
  <source url="https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/5913693" />
  <guid>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/5913693</guid>
  <fb20:id>5913693</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Dear Nicolas,&lt;/p&gt;&lt;p&gt;Thank you very much for a thorough answer! &lt;/p&gt;&lt;p&gt;OK, so I can exchange security keys from my TahomaPad. I suppose scenarios cannot be transferred? So far I used Set&amp;amp;Go USB Module with Set&amp;amp;Go Windows software for e.g. setting upper and lower limits for blinds. Do I still need Set&amp;amp;Go or can I Config ure from Tahima itself?&lt;/p&gt;&lt;p&gt;PS. I&amp;#39;m from Slovenia but our country is not on the list of available countries on somfy-connect.com?! How would I register my new Tahoma Din Rail? &lt;/p&gt;&lt;p&gt;Thanks again! Best Regards, &lt;br /&gt;Grega&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 09 Sep 2020 12:37:50 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/5911510</link>
  <source url="https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/5911510" />
  <guid>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/5911510</guid>
  <fb20:id>5911510</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello Gregor,&lt;br /&gt;1/ no there is no wifi module included inside the tahoma rail din you have to buy the extra wifi-module but there is some pack with tahoma rail din + wifi module.&lt;/p&gt;&lt;p&gt;2/ with no internet connection tahoma still launch agenda&amp;#39;s scénario already configured but you can&amp;#39;t change or acces to it.&lt;/p&gt;&lt;p&gt;3/ Yes you can install it in a steel cabinet&lt;/p&gt;&lt;p&gt;4/ There is no videophone compatible with tahoma.&lt;/p&gt;&lt;p&gt;5/ yes of course&lt;/p&gt;&lt;p&gt;6/ Yes tahoma rail din is compatible with somfy protect&lt;/p&gt;&lt;p&gt;7/ Yes it&amp;#39;s possible but only in app configuration not web interface&lt;/p&gt;&lt;p&gt;8/ Yes if you want to find your device in tahoma rail din you have to exchange the IO security Key of your tahoma pad with tahoma rail din.&lt;/p&gt;&lt;p&gt;Have a nice day&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 09 Sep 2020 11:56:44 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/5911323</link>
  <source url="https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/5911323" />
  <guid>https://forum.somfy.fr/questions/2445225-tahoma-din-rail-installation/answers/5911323</guid>
  <fb20:id>5911323</fb20:id>
