    <title>[Forum Somfy] Suivi de la question: Wifi Connection to Protexiom</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F2562734" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Wifi Connection to Protexiom</description>
    <pubDate>Mon, 11 Jan 2021 15:08:02 GMT</pubDate>
    <lastBuildDate>Mon, 11 Jan 2021 15:08:02 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Good Afternoon Dimitrios,&lt;/p&gt;&lt;p&gt;Yes, the batteries of your central unit seem to be totaly empties. Begin to replace the four LR20 batteries.&lt;/p&gt;&lt;p&gt;Regards,&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6268348</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6268348" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6268348</guid>
  <fb20:id>6268348</fb20:id>
  <fb20:question-id>2562734</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi, I have installed a Protexiom GSM system in my house. The alarm system works perfectly. Also I have access to it using the mobile app on my phone when I am connected to the in house router. &lt;br /&gt;The issue is that I cannot connect using my mobile app when I am connected to the internet outside the house. I have done everything listed in the manual but when I try to use the alarmsomfy.eu page to create an account and link the unit the system stays at the first page searching and not finding the central unit. I have tried everything and I am very frustrated that it does not work. Can you please help me find what the issue is and solve it ? thanks a lot&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de Dimitrios T.</title>
  <dc:creator>Dimitrios T.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Good morning. Suddenly I have no access to my protexiom GSM unit by any means WiFi. Keypad or other. &lt;br /&gt;By taping Menu and my code I get the message “phone diaper missing”. I recently had notification from the unit that the Phone Dialer battery is low. Can it be that this is the issue? Would this be solved by replacing the battery ? Thanks for your guidance&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 11 Jan 2021 12:47:45 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6267656</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6267656" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6267656</guid>
  <fb20:id>6267656</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/16735491</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello again, further to my previous message, can you please send me config directions for my actual router type? I have downloaded the instructions of the listed router in my account (OTE-ADSL ZTEZHXN-H108NS) but they have no relation to the actual router (ZTE ZXHN H168N) configurable parameters which is very confusing. thanks a lot&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 08 Jan 2021 11:33:17 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6260203</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6260203" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6260203</guid>
  <fb20:id>6260203</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;also i now cannot connect to the main unit even from my LAN. it seems that the user codes do not work anymore? is this something that you do or should I reset the Central Unit ?&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 08 Jan 2021 11:04:13 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6260100</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6260100" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6260100</guid>
  <fb20:id>6260100</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;thank you. &lt;br /&gt;I connected to my account and show the following:&lt;br /&gt;HTTP is 80, HTTPS is 443&lt;br /&gt;I see the following error messages when in configuration page:&lt;br /&gt;error no magic box found &lt;br /&gt;error code 500&lt;br /&gt;Also the modem type appears as OTE-ADSL ZTEZHXN-H108NS while the actual one is ZTE ZHXN-H168N. &lt;br /&gt;does this play a role ?&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 08 Jan 2021 10:57:09 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6260074</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6260074" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6260074</guid>
  <fb20:id>6260074</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Good Morning Dimitrios,&lt;/p&gt;&lt;p&gt;The 80 port fowarding is working but not the 443.&lt;/p&gt;&lt;p&gt;Can you connect to your account at the link below in user account : &lt;/p&gt;&lt;p&gt;&lt;a href=&quot;https://www.alarmsomfy.eu&quot; rel=&quot;nofollow&quot;&gt;https://www.alarmsomfy.eu&lt;/a&gt;&lt;/p&gt;&lt;p&gt;Then click on configuration, are the ports HTTP and HTTPS are 80 and 443 ?&lt;/p&gt;&lt;p&gt;Regards,&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 08 Jan 2021 10:11:01 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6259804</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6259804" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6259804</guid>
  <fb20:id>6259804</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Good afternoon . &lt;br /&gt;Following my last response, is there something you advise me to do to make it work ? Thanks a lot for your update&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 07 Jan 2021 16:25:01 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6257896</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6257896" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6257896</guid>
  <fb20:id>6257896</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;OK changed it to 192.168.1.254 which is the LAN IP for the router. still does not work&lt;br /&gt;I send you the port forwarding setting of the router. Please let me know if OK or what else to check. Thanks&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 06 Jan 2021 15:49:46 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6254156</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6254156" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6254156</guid>
  <enclosure length="110240" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/e64156df99772473/screen_shot_2021_01_06_at_17.42.45_original.png?64d4a32" type="image/png" />
<enclosure length="111028" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/1ebb83a51f322efb/screen_shot_2021_01_06_at_17.43.30_original.png?64d4a32" type="image/png" />
<enclosure length="29688" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/696c28a9d0542bb3/screen_shot_2021_01_06_at_17.47.54_original.png?64d4a32" type="image/png" />
<enclosure length="29793" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/48cdfc0469cd1492/screen_shot_2021_01_06_at_17.48.19_original.png?64d4a32" type="image/png" />
  <fb20:id>6254156</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Dimitrios,&lt;/p&gt;&lt;p&gt;If the Modem IP address IS 192.168.1.254, the Primary DNS should not be 192.168.1.1. Can you change this D.N.S. in order to have 192.168.1.254 ?&lt;/p&gt;&lt;p&gt;Regards,&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 06 Jan 2021 14:46:07 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6253900</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6253900" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6253900</guid>
  <fb20:id>6253900</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;please see my current settings (attached) . also my rooter type in case you can direct me to certain checks is ZTE ZXHN H168N. Thanks again for your kind help&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 06 Jan 2021 13:40:31 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6253581</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6253581" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6253581</guid>
  <enclosure length="39889" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/67a92151aad48d7f/screen_shot_2021_01_06_at_15.36.37_original.png?64d4a32" type="image/png" />
<enclosure length="46140" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/d7eceb952c928df7/screen_shot_2021_01_06_at_15.37.13_original.png?64d4a32" type="image/png" />
  <fb20:id>6253581</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;thank you Thomas. I have tried to connect using the specified domain name for remote connection but i get the message: network not available, check your connection. I have used an online tool to check ports status and both ports 80 &amp;amp; 443 are open. Any idea as to what to check or do further ? thanks a lot&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 06 Jan 2021 13:16:16 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6253484</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6253484" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6253484</guid>
  <fb20:id>6253484</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Good Morning Dimitrios,&lt;/p&gt;&lt;p&gt;You already create an account with this Transmistter and you can create only one account for one equipment.&lt;/p&gt;&lt;p&gt;I just sent your account information by email.&lt;/p&gt;&lt;p&gt;Regards,&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 06 Jan 2021 11:10:46 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6252915</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6252915" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6252915</guid>
  <fb20:id>6252915</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi !&lt;/p&gt;&lt;p&gt;We must now be patient. It&amp;#39;s a Yellow (technician) that will contact you very soon.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 05 Jan 2021 12:34:46 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6249710</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6249710" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6249710</guid>
  <fb20:id>6249710</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Dear Jean-Luc, Thank you for updating me on next steps&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 05 Jan 2021 11:26:00 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6249385</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6249385" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6249385</guid>
  <fb20:id>6249385</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;transmitter number is 619988 thanks&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 04 Jan 2021 19:34:39 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247664</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247664" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247664</guid>
  <fb20:id>6247664</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;The 6-digit number is the first in the &amp;quot;list of items&amp;quot;. You can also find it on a label affixed to the side of the transmitter. (As on the attached example)&lt;/p&gt;&lt;p&gt;regards !&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 04 Jan 2021 19:26:12 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247635</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247635" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247635</guid>
  <enclosure length="1369883" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/4f3b4a68ef7a24d8/image_original.png?64d4a32" type="image/png" />
  <fb20:id>6247635</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;thank you for your quick reply. I have installed it new a couple of years back. I have now tried to use the wifi access app. Not sure if I have created an account in the past. Can you help me with where to find the 6 digit transmitter number ?&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 04 Jan 2021 17:58:53 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247350</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247350" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247350</guid>
  <fb20:id>6247350</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello&lt;/p&gt;&lt;p&gt;Is your Protexiom system new?&lt;br /&gt;Otherwise, an account may already exist.&lt;br /&gt;Leave the 6-digit transmitter number here. (This number starts with 5 or 6) and a Yellow will check if there is already an account.&lt;/p&gt;&lt;p&gt;Have a good day !&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 04 Jan 2021 17:19:03 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247214</link>
  <source url="https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247214" />
  <guid>https://forum.somfy.fr/questions/2562734-wifi-connection-to-protexiom/answers/6247214</guid>
  <fb20:id>6247214</fb20:id>
