    <title>[Forum Somfy] Suivi de la question: Keygo io programming</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F2689068" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Keygo io programming</description>
    <pubDate>Mon, 24 May 2021 13:17:23 GMT</pubDate>
    <lastBuildDate>Mon, 24 May 2021 13:17:23 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;You can put this RTS receiver on the Dexxo IO, so you can use the Keypop RTS on both engines (Elvovia + Dexxo)&lt;br /&gt;&lt;a href=&quot;https://boutique.somfy.fr/recepteur-portail-porte-de-garage-rts-exterieur.html&quot; rel=&quot;nofollow&quot;&gt;https://boutique.somfy.fr/recepteur-portail-porte-de-gara...&lt;/a&gt;&lt;/p&gt;&lt;p&gt;Best regards&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/2689068-keygo-io-programming/answers/6786525</link>
  <source url="https://forum.somfy.fr/questions/2689068-keygo-io-programming/answers/6786525" />
  <guid>https://forum.somfy.fr/questions/2689068-keygo-io-programming/answers/6786525</guid>
  <fb20:id>6786525</fb20:id>
  <fb20:question-id>2689068</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;br /&gt;Iam sorry my French is not good. We have a new house with a &amp;quot;Dexxo Pro io&amp;quot; garage door opener worked by a four button &amp;quot;Keygo io&amp;quot; remote. Have just had some gates fitted &amp;quot;Evolvia 400&amp;quot; motors with a &amp;quot;Keypop 2 RTS&amp;quot; remote how do I get one of the &amp;quot;Keygo&amp;quot; smaller buttons to operate the gates? &lt;br /&gt;Merci&lt;/p&gt;&lt;p&gt;Merci,&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de Sheena R.</title>
  <dc:creator>Sheena R.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Thankyou, as I thought, different frequency, all the house is Somfy, I thought it was all compatible, as a full house automation system, it appears not, so I have to have two remotes in the car! Thanks again&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 24 May 2021 12:54:15 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2689068-keygo-io-programming/answers/6786452</link>
  <source url="https://forum.somfy.fr/questions/2689068-keygo-io-programming/answers/6786452" />
  <guid>https://forum.somfy.fr/questions/2689068-keygo-io-programming/answers/6786452</guid>
  <fb20:id>6786452</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/17413981</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello,&lt;/p&gt;&lt;p&gt;You will not be able to assign a Keygo IO button on an RTS portal.&lt;br /&gt;IO = 868MHz&lt;br /&gt;RTS = 433MHz&lt;/p&gt;&lt;p&gt;Best regards;&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 24 May 2021 12:35:45 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2689068-keygo-io-programming/answers/6786394</link>
  <source url="https://forum.somfy.fr/questions/2689068-keygo-io-programming/answers/6786394" />
  <guid>https://forum.somfy.fr/questions/2689068-keygo-io-programming/answers/6786394</guid>
  <fb20:id>6786394</fb20:id>
