    <title>[Forum Somfy] Suivi de la question: Programmation Tahoma Switch ou Somfy Situo5 avec Velux KSI310</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F2951984" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Programmation Tahoma Switch ou Somfy Situo5 avec Velux KSI310</description>
    <pubDate>Sun, 22 May 2022 13:20:25 GMT</pubDate>
    <lastBuildDate>Sun, 22 May 2022 13:20:25 GMT</lastBuildDate>
  <title>Réponse de Paul G.</title>
  <dc:creator>Paul G.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;I found the solution:&lt;/p&gt;&lt;p&gt;Using Velux Wall Switch With Somfy Device:&lt;br /&gt;1) Select the desired Channel on the Situo 5 (par ex ch1)&lt;br /&gt;2) SITUO5 - Press &amp;amp; hold PROG until the stores moves&lt;br /&gt;3) KLI310 - Short Press the WINDOW button program&lt;br /&gt;4) If successful, the stores will move again. (should take 1 or 2s)&lt;/p&gt;&lt;p&gt;Using Somfy Situo with Velux Stores:&lt;br /&gt;1) KLI310 - Press &amp;amp; hold the GEAR button until the window moves&lt;br /&gt;2) SITUO - Pres the PROG button to program&lt;br /&gt;3) If successful, the window will move again. (should take 1 or 2s)&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/2951984-programmation-tahoma-switch-somfy-situo5-velux-ksi310/answers/7677103</link>
  <source url="https://forum.somfy.fr/questions/2951984-programmation-tahoma-switch-somfy-situo5-velux-ksi310/answers/7677103" />
  <guid>https://forum.somfy.fr/questions/2951984-programmation-tahoma-switch-somfy-situo5-velux-ksi310/answers/7677103</guid>
  <fb20:id>7677103</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/18692255</fb20:author-profile>
  <fb20:question-id>2951984</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;br /&gt;J&amp;#39;ai deux stores avec motorisation &amp;quot;Moteur Somfy radio IO pour tube à goutte de 78 mm&amp;quot; et un telecommande Situo 5 IO Pure.&lt;/p&gt;&lt;p&gt;Ca functionne bien avec le Tahoma Switch.&lt;/p&gt;&lt;p&gt;Est-il possible de programmer un Switch mural Velux KSI 310 pour controler le stores?&lt;/p&gt;&lt;p&gt;Je pense le KSI310 utiliser le meme protocol (IO) et je dois juste echanger le key entre le Situo (par ex Canal1) ou le Tahoma Switch et le KSI310 ?&lt;/p&gt;&lt;p&gt;Est-ce que quelqu&amp;#39;un connaît la process de l&amp;#39;appairage ?&lt;/p&gt;&lt;p&gt;Merci beaucoup de votre assistance,&lt;/p&gt;&lt;p&gt;Gabbo CH&lt;/p&gt;&lt;/div&gt;
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Merci Andre, &amp;#39;cest vrai, c&amp;#39;est le KLI 310.&lt;/p&gt;&lt;p&gt;J&amp;#39;ai trouvé la solution:&lt;/p&gt;&lt;p&gt;Pour Utiliser Velux Switch Mural Avec Appareil Somfy:&lt;br /&gt;    1) Sélectionnez le canal souhaité sur le Situo 5 (par ex ch1)&lt;br /&gt;   2) SITUO5 - Appuyez et maintenez PROG jusqu&amp;#39;à ce que le stores bouge&lt;br /&gt;3) KLI310 - Appuyez brièvement sur le bouton WINDOW pour programmé&lt;br /&gt;4) En cas de succès, le store bouge à nouveau. (devrait prendre 1 ou 2s)&lt;/p&gt;&lt;p&gt;Utiliser Somfy Situo avec Velux Stores :&lt;br /&gt;    1) KLI310 - Appuyez et maintenez enfoncé le bouton GEAR jusqu&amp;#39;à ce que la fenêtre bouge&lt;br /&gt;    2) SITUO - Appuyez brièvement sur le bouton PROG pour programmer&lt;br /&gt;    3) En cas de succès, le finetre bouge à nouveau.  (devrait prendre 1 ou 2s)&lt;/p&gt;&lt;/div&gt;
  <pubDate>Sun, 22 May 2022 13:18:47 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2951984-programmation-tahoma-switch-somfy-situo5-velux-ksi310/answers/7677101</link>
  <source url="https://forum.somfy.fr/questions/2951984-programmation-tahoma-switch-somfy-situo5-velux-ksi310/answers/7677101" />
  <guid>https://forum.somfy.fr/questions/2951984-programmation-tahoma-switch-somfy-situo5-velux-ksi310/answers/7677101</guid>
  <fb20:id>7677101</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour &lt;/p&gt;&lt;p&gt;C’est kli 310 plutôt non ? Le bouton d apparaître c’est le bouton en forme d engrenage.&lt;/p&gt;&lt;p&gt;Donc prog sur la situo jusqu’aux mouvements puis le bouton engrenage.&lt;/p&gt;&lt;p&gt;Bonne journée.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Sun, 22 May 2022 05:01:18 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/2951984-programmation-tahoma-switch-somfy-situo5-velux-ksi310/answers/7676467</link>
  <source url="https://forum.somfy.fr/questions/2951984-programmation-tahoma-switch-somfy-situo5-velux-ksi310/answers/7676467" />
  <guid>https://forum.somfy.fr/questions/2951984-programmation-tahoma-switch-somfy-situo5-velux-ksi310/answers/7676467</guid>
  <fb20:id>7676467</fb20:id>
