    <title>[Forum Somfy] Suivi de la question: Tahoma Switch and Situo 5 remote</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F3019874" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Tahoma Switch and Situo 5 remote</description>
    <pubDate>Sat, 17 Sep 2022 16:22:24 GMT</pubDate>
    <lastBuildDate>Sat, 17 Sep 2022 16:22:24 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;OK Gregor, I better understand now. &lt;br /&gt;You may try to add each channel as a scenario launcher, using scenario launcher button style. But in this case, you can use an arrow up/down to add a or more shutter behavior.&lt;/p&gt;&lt;p&gt;I don&amp;#39;t know if it will works as situo is not a scenario launcher.&lt;/p&gt;&lt;p&gt;Normally, you should add each shutter directly on the situo by taking one remote control of a shutter, press prog on the back until a movement and after select a chanel on the situo, press prog on the back and the situo chanel is memorized by the shutter.&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/3019874-tahoma-switch-and-situo-5-remote/answers/7856672</link>
  <source url="https://forum.somfy.fr/questions/3019874-tahoma-switch-and-situo-5-remote/answers/7856672" />
  <guid>https://forum.somfy.fr/questions/3019874-tahoma-switch-and-situo-5-remote/answers/7856672</guid>
  <fb20:id>7856672</fb20:id>
  <fb20:question-id>3019874</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello!&lt;/p&gt;&lt;p&gt;I&amp;#39;m using Tahoma Switch with roller shutters and it all works just fine. So far I only used Tahoma app on mobile phone but I still have an &amp;quot;old&amp;quot; Situo 5 io Variation a/m which I would like to use with the system. How can I connect Situo 5 io to Tahoma Switch and then configure which shutters (or group of shutters) to steer with Situo 5? I hope it is possible to do the programming without Set&amp;amp;Go.&lt;/p&gt;&lt;p&gt;Many thanks for your answers!&lt;/p&gt;&lt;p&gt;Kind Regars,&lt;br /&gt;Grega&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de Gregor B.</title>
  <dc:creator>Gregor B.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Dear Andre!&lt;/p&gt;&lt;p&gt;Thank you for your answer. I&amp;#39;m not fully sure that we understand. So I have Somfy Switch and 18 io motors for shutters. Everything is configured and working: I can control shutters with Tahoma App on my mobile phone. &lt;/p&gt;&lt;p&gt;What I&amp;#39;m asking is that I have a Somfy Situo 5 io remote that I would also like to use in paralel. It has 5 channels but it is not properly configured. I would like to configure these 5 channels to open/close specific shutters, but I really was not able to add Situo to Tahoma. &lt;/p&gt;&lt;p&gt;I tried to &amp;quot;Add an equipment&amp;quot; in Tahoma App but then struggle what option to select and I never managed to add Situo remote. &lt;/p&gt;&lt;p&gt;Then I would like to add individual shutters to channels of Situo in order not to need mobile phone everywhere in my house e.g. just to close-all in the evening.&lt;/p&gt;&lt;p&gt;Can you please help me with this?&lt;/p&gt;&lt;p&gt;Kind Regards,&lt;br /&gt;Grega&lt;/p&gt;&lt;/div&gt;
  <pubDate>Sat, 17 Sep 2022 15:42:11 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3019874-tahoma-switch-and-situo-5-remote/answers/7856621</link>
  <source url="https://forum.somfy.fr/questions/3019874-tahoma-switch-and-situo-5-remote/answers/7856621" />
  <guid>https://forum.somfy.fr/questions/3019874-tahoma-switch-and-situo-5-remote/answers/7856621</guid>
  <fb20:id>7856621</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/6723765</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi,&lt;/p&gt;&lt;p&gt;Adding shutters with old situo IO works the same way as other remote control, just choose your chanel, press PROG on the bag until the mouvement of your shutters and do a search on tahoma.&lt;/p&gt;&lt;p&gt;The only things is that if there already exists an IO key on thoses shutters, when you will need to reset them or harmonize the key with a set&amp;amp;go.&lt;/p&gt;&lt;p&gt;regards.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 14 Sep 2022 18:18:23 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3019874-tahoma-switch-and-situo-5-remote/answers/7851718</link>
  <source url="https://forum.somfy.fr/questions/3019874-tahoma-switch-and-situo-5-remote/answers/7851718" />
  <guid>https://forum.somfy.fr/questions/3019874-tahoma-switch-and-situo-5-remote/answers/7851718</guid>
  <fb20:id>7851718</fb20:id>
