    <title>[Forum Somfy] Suivi de la question: Comment se connecter à l&#39;API de la gateway Tahoma ?</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F3157112" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Comment se connecter à l&#39;API de la gateway Tahoma ?</description>
    <pubDate>Mon, 17 Apr 2023 08:52:59 GMT</pubDate>
    <lastBuildDate>Mon, 17 Apr 2023 08:52:59 GMT</lastBuildDate>
  <title>Réponse de Lou L.</title>
  <dc:creator>Lou L.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;/p&gt;&lt;p&gt;Vous devriez trouver réponse à vos questions dans la documentation : &lt;a href=&quot;https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode&quot; rel=&quot;nofollow&quot;&gt;https://github.com/Somfy-Developer/Somfy-TaHoma-Developer...&lt;/a&gt;&lt;br /&gt;&lt;a href=&quot;https://somfy-developer.github.io/Somfy-TaHoma-Developer-Mode/&quot; rel=&quot;nofollow&quot;&gt;https://somfy-developer.github.io/Somfy-TaHoma-Developer-...&lt;/a&gt;&lt;/p&gt;&lt;p&gt;Vous verrez notamment que l&amp;#39;url à construire est : &lt;br /&gt;&lt;a href=&quot;https://gateway-1111-2222-3333.local:8443/enduser-mobile-web/1/enduserAPI&quot; rel=&quot;nofollow&quot;&gt;https://gateway-1111-2222-3333.local:8443/enduser-mobile-...&lt;/a&gt;&lt;/p&gt;&lt;p&gt;Si toutefois le problème persiste, privilégiez un Issue ici (&lt;a href=&quot;https://github.com/Somfy-Developer/Somfy-TaHoma-Developer-Mode/issues&quot; rel=&quot;nofollow&quot;&gt;https://github.com/Somfy-Developer/Somfy-TaHoma-Developer...&lt;/a&gt;) pour obtenir du support.&lt;/p&gt;&lt;p&gt;Cordialement&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/3157112-connecter-api-gateway-tahoma/answers/8194874</link>
  <source url="https://forum.somfy.fr/questions/3157112-connecter-api-gateway-tahoma/answers/8194874" />
  <guid>https://forum.somfy.fr/questions/3157112-connecter-api-gateway-tahoma/answers/8194874</guid>
  <fb20:id>8194874</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/11846029</fb20:author-profile>
  <fb20:author-avatar>https://dimelo-users-production.s3-eu-west-1.amazonaws.com/identity_avatars/70c1fee1c0bf190d/avatar_normal.png?7cc8cfd</fb20:author-avatar>
  <fb20:question-id>3157112</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;/p&gt;&lt;p&gt;Cela fait quelque temps que j&amp;#39;utilise le mode développeur de mon boitier Tahoma Somfy. Je n&amp;#39;avais aucun mal à l&amp;#39;utiliser et tout marchait normalement jusqu&amp;#39;à ce que change de routeur la semaine dernière. Je tiens à dire que l&amp;#39;application smartphone de pilotage fonctionne sans problème, mais je n&amp;#39;arrive pas à utiliser l&amp;#39;API de ma Tahoma.&lt;/p&gt;&lt;p&gt;Tout d&amp;#39;abord, le nom de ma gateway au sein de mon réseau ne correspond pas à son PIN complet. Sur mon réseau, la Tahoma est identifié comme gateway-1111-2222, cependant le PIN complet est 1111-2222-3333. J&amp;#39;ai bien tenté de renommer la gateway pour inclure les chiffres manquants du PIN et j&amp;#39;arrive à atteindre l&amp;#39;équipement à l&amp;#39;aide d&amp;#39;un ping, toutefois, lorsque j&amp;#39;essaye d&amp;#39;effectuer des requêtes sur l&amp;#39;API, je reçois une erreur &amp;quot;Connection refused&amp;quot;. J&amp;#39;ai essayé différentes choses, mais je n&amp;#39;ai jamais réussi à la refaire fonctionner. Et je tiens à préciser qu&amp;#39;avant de changer mon routeur, j&amp;#39;arrivais bel et bien à envoyer des requêtes à l&amp;#39;API.&lt;/p&gt;&lt;p&gt;J&amp;#39;aimerais donc savoir si vous aviez une idée de ce qui pouvait poser ce genre d&amp;#39;erreur. Se pourrait-il qu&amp;#39;il s&amp;#39;agisse d&amp;#39;un problème de port ? Il ne me semble pas qu&amp;#39;il soit possible de configurer le port associé à l&amp;#39;API.&lt;/p&gt;&lt;p&gt;EDIT: En observant les trames MDNs, le nom parait être &amp;quot;gateway-1111-2222-3333.local&amp;quot;, cependant, lorsque j&amp;#39;essaye d&amp;#39;envoyer une requête HTTP, je reçois une erreur &amp;quot;Could not resolve host&amp;quot;, si je remplace le &amp;quot;.local&amp;quot; par .&amp;quot;home&amp;quot;, le host est trouvé, mais l&amp;#39;erreur que je reçois est &amp;quot;Connection refused&amp;quot;.  Avant de changer mon routeur, j&amp;#39;utilisais aussi le &amp;quot;.home&amp;quot; que j&amp;#39;avais testé lorsque je n&amp;#39;arrivais pas à faire fonctionner avec le &amp;quot;.local&amp;quot;.&lt;/p&gt;&lt;p&gt;Au cas où, voici la requête que j&amp;#39;utilise actuellement (et qui fonctionnait avant de changer mon routeur) :&lt;br /&gt;curl &lt;a href=&quot;https://gateway-1111-2222-3333.home:8443/enduser-mobile-web/1/enduserAPI/apiVersion&quot; rel=&quot;nofollow&quot;&gt;https://gateway-1111-2222-3333.home:8443/enduser-mobile-w...&lt;/a&gt; -H &amp;#39;accept: application/json&amp;#39; -H &amp;quot;Authorization: Bearer ABCDE0123456789&amp;quot;&lt;/p&gt;&lt;p&gt;J&amp;#39;ai également testé de générer et d&amp;#39;activer un nouveau token, mais l&amp;#39;erreur est la même.&lt;/p&gt;&lt;p&gt;Merci d&amp;#39;avance,&lt;/p&gt;&lt;/div&gt;
