    <title>[Forum Somfy] Suivi de la question: can&#39;t reset to default smoke detector io alarm tahoma</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F3391616" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: can&#39;t reset to default smoke detector io alarm tahoma</description>
    <pubDate>Thu, 08 Aug 2024 07:22:25 GMT</pubDate>
    <lastBuildDate>Thu, 08 Aug 2024 07:22:25 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello Mihai, &lt;br /&gt;I have responded to you in another post that this detector is probably defective. You will need to contact customer service through your retailer if the product is still under warranty.&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/3391616-can-reset-to-default-smoke-detector-io-alarm-tahoma/answers/8802406</link>
  <source url="https://forum.somfy.fr/questions/3391616-can-reset-to-default-smoke-detector-io-alarm-tahoma/answers/8802406" />
  <guid>https://forum.somfy.fr/questions/3391616-can-reset-to-default-smoke-detector-io-alarm-tahoma/answers/8802406</guid>
  <fb20:id>8802406</fb20:id>
  <fb20:question-id>3391616</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;/p&gt;&lt;p&gt;I have a Somfy smoke alarm IO with the following serials on its back:&lt;br /&gt;A02 D 18 188 B  5127598  0333-CPR-292133-1&lt;br /&gt;I used it successfully for the past several years (also added in Tahoma box) until it ran out of battery and I had to replace the battery (the small one, not the 9V one). However, after battery change I saw that in Tahoma it was still reported as low battery. &lt;br /&gt;I removed it from Tahoma and tried to add it again. The reset procedure specifies to hold the test button pressed until I hear 6 beeps - I did like this and I heard 6 beeps grouped by 3. &lt;br /&gt;However, I believe that the sensor was not reset because the led didn&amp;#39;t start to blink indefinitely. I tried to add it to Tahoma but on web page it said that the sensor was not found.&lt;/p&gt;&lt;p&gt;My question: how can I hardware reset somehow this sensor because it seems the option with 6 beeps is not working. &lt;br /&gt;Also, while adding in Tahoma it says I need to press the test button more than 5 seconds until the led reacts - but in what way it reacts?&lt;/p&gt;&lt;p&gt;Other than that, the smoke detector seems to be operational since the test led blinks once each 60 seconds signaling it is healthy.&lt;/p&gt;&lt;p&gt;Merci,&lt;br /&gt;Mihai&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de Mihai M.</title>
  <dc:creator>Mihai M.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;/p&gt;&lt;p&gt;J&amp;#39;ai un détecteur de fumée Somfy IO avec les numéros de série suivants au dos :&lt;br /&gt;A02 D 18 188 B 5127598 0333-CPR-292133-1&lt;br /&gt;Je l&amp;#39;ai utilisé avec succès au cours des dernières années (également ajouté dans la boîte Tahoma) jusqu&amp;#39;à ce qu&amp;#39;il n&amp;#39;y ait plus de batterie et que je doive remplacer la batterie (la petite, pas celle de 9 V). Cependant, après avoir changé la batterie, j&amp;#39;ai vu que dans Tahoma, elle était toujours signalée comme une batterie faible.&lt;br /&gt;Je l&amp;#39;ai retiré de Tahoma et j&amp;#39;ai essayé de l&amp;#39;ajouter à nouveau.  La procédure de réinitialisation spécifie de maintenir le bouton de test enfoncé jusqu&amp;#39;à ce que j&amp;#39;entende 6 bips - j&amp;#39;ai fait comme ça et j&amp;#39;ai entendu 6 bips groupés par 3.&lt;br /&gt;Cependant, je pense que le capteur n&amp;#39;a pas été réinitialisé car la LED n&amp;#39;a pas commencé à clignoter indéfiniment. J&amp;#39;ai essayé de l&amp;#39;ajouter à Tahoma mais sur la page Web, il était indiqué que le capteur n&amp;#39;était pas trouvé.&lt;/p&gt;&lt;p&gt;Ma question : comment puis-je réinitialiser matériellement ce capteur d&amp;#39;une manière ou d&amp;#39;une autre car il semble que l&amp;#39;option avec 6 bips ne fonctionne pas.&lt;br /&gt;De plus, lors de l&amp;#39;ajout dans Tahoma, il est indiqué que je dois appuyer sur le bouton de test plus de 5 secondes jusqu&amp;#39;à ce que la LED réagisse - mais de quelle manière réagit-elle ?&lt;/p&gt;&lt;p&gt;À part cela, le détecteur de fumée semble être opérationnel puisque la LED de test clignote une fois toutes les 60 secondes, ce qui indique qu&amp;#39;il est en bon état.&lt;/p&gt;&lt;p&gt;J&amp;#39;ai également une nouvelle pile CR123 à l&amp;#39;intérieur du détecteur de fumée.&lt;/p&gt;&lt;p&gt;Merci,&lt;br /&gt;Mihai&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 07 Aug 2024 11:09:18 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3391616-can-reset-to-default-smoke-detector-io-alarm-tahoma/answers/8801495</link>
  <source url="https://forum.somfy.fr/questions/3391616-can-reset-to-default-smoke-detector-io-alarm-tahoma/answers/8801495" />
  <guid>https://forum.somfy.fr/questions/3391616-can-reset-to-default-smoke-detector-io-alarm-tahoma/answers/8801495</guid>
  <fb20:id>8801495</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/19951063</fb20:author-profile>
  <fb20:author-avatar>https://dimelo-users-production.s3.amazonaws.com/identity_avatars/9aa8bd3645f41c61/avatar_normal.png?bb28c87</fb20:author-avatar>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello,&lt;/p&gt;&lt;p&gt;You are addressing a French forum.&lt;br /&gt;At least for the sake of politeness, please write in French so that the community understands you.&lt;br /&gt;Just use Google translate.&lt;br /&gt;Or, please contact Somfy support in your country.&lt;/p&gt;&lt;p&gt;Have a nice day&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 07 Aug 2024 07:57:19 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3391616-can-reset-to-default-smoke-detector-io-alarm-tahoma/answers/8801022</link>
  <source url="https://forum.somfy.fr/questions/3391616-can-reset-to-default-smoke-detector-io-alarm-tahoma/answers/8801022" />
  <guid>https://forum.somfy.fr/questions/3391616-can-reset-to-default-smoke-detector-io-alarm-tahoma/answers/8801022</guid>
  <fb20:id>8801022</fb20:id>
