    <title>[Forum Somfy] Suivi de la question: Compatibilité crémaillère Somfy freevia 280/300</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F3599001" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Compatibilité crémaillère Somfy freevia 280/300</description>
    <pubDate>Tue, 20 May 2025 11:41:18 GMT</pubDate>
    <lastBuildDate>Tue, 20 May 2025 11:41:18 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;On pourrait réparer la crémaillère ...&lt;/p&gt;&lt;p&gt;Mais avant faut chercher ça doit se trouver &lt;br /&gt;&lt;a href=&quot;https://www.google.com/imgres?q=cremaill%C3%A8re%20haute&amp;amp;imgurl=https%3A%2F%2Fmedia.adeo.com%2Fmedia%2F1114377%2Fmedia.jpg%3Fwidth%3D650%26height%3D650%26format%3Djpg%26quality%3D80%26fit%3Dbounds&amp;amp;imgrefurl=https%3A%2F%2Fwww.leroymerlin.fr%2Fproduits%2Fcremaillere-3-x-33-cm-fixation-haute-pour-portail-coulissant-slidymoove-somfy-62845685.html&amp;amp;docid=7yGOoDst8AerqM&amp;amp;tbnid=yTZj3MmNt4nV7M&amp;amp;vet=12ahUKEwiE1_3i-rGNAxUJSKQEHaeUJSMQM3oECB4QAA..i&amp;amp;w=650&amp;amp;h=284&amp;amp;hcb=2&amp;amp;ved=2ahUKEwiE1_3i-rGNAxUJSKQEHaeUJSMQM3oECB4QAA&quot; rel=&quot;nofollow&quot;&gt;https://www.google.com/imgres?q=cremaill%C3%A8re%20haute&amp;...&lt;/a&gt;&lt;br /&gt;&lt;a href=&quot;https://www.google.com/url?sa=i&amp;amp;url=https%3A%2F%2Fwww.leboncoin.fr%2Fad%2Fbricolage%2F2980679365&amp;amp;psig=AOvVaw3KiA31QVpJuFpkmZdJyCS2&amp;amp;ust=1747827684311000&amp;amp;source=images&amp;amp;cd=vfe&amp;amp;opi=89978449&amp;amp;ved=0CBYQ3YkBahcKEwi4xvbr-7GNAxUAAAAAHQAAAAAQAw&quot; rel=&quot;nofollow&quot;&gt;https://www.google.com/url?sa=i&amp;amp;url=https%3A%2F%2Fwww...&lt;/a&gt;&lt;/p&gt;&lt;p&gt;Il serait bon  de centrer le pignon sur la crémaillère !&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102823</link>
  <source url="https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102823" />
  <guid>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102823</guid>
  <fb20:id>9102823</fb20:id>
  <fb20:question-id>3599001</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour, j&amp;#39;ai un moteur freevia 280/300 avec une crémaillère basse je pense comme sur la photo, mais je ne trouve pas de crémaillère compatible, car sur le nouveau modèle il y a bien stipulé dessus non compatible avec freevia 280/300. &lt;br /&gt;Je dois changer toute la crémaillère ? Et la quelle est compatible avec mon moteur. &lt;br /&gt;Photo ci joint. &lt;br /&gt;Merci de vos réponses &lt;/p&gt;&lt;p&gt;Merci,&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de Loic G.</title>
  <dc:creator>Loic G.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour richy c. &lt;br /&gt;Merci de votre réponse, moi je veux juste changer soite le bout casser de ma crémaillère que je ne trouve plus. Ou changer toute crémaillère, mais je ne sais pas laquelle est compatible avec mon moteur. Pouvez vous m&amp;#39;aider . Cordialement&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 20 May 2025 10:03:28 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102673</link>
  <source url="https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102673" />
  <guid>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102673</guid>
  <fb20:id>9102673</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/20199381</fb20:author-profile>
  <fb20:author-avatar>https://dimelo-users-production.s3.amazonaws.com/identity_avatars/7b1f0dd71d7423ae/avatar_normal.png?c6832e6</fb20:author-avatar>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour coyote. &lt;br /&gt;Je n&amp;#39;ai pas d problème avec le moteur et il n&amp;#39;y a pas de poids dessus . Le rail a cassé car la fille de 4 ans a foncé dessus avec son tricycle.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 20 May 2025 10:01:44 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102669</link>
  <source url="https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102669" />
  <guid>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102669</guid>
  <fb20:id>9102669</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;/p&gt;&lt;p&gt;On ne remplace pas une motorisation pour un petit problème de crémaillère.&lt;br /&gt;Renseignez-vous mieux, exemple :&lt;br /&gt;&lt;a href=&quot;https://www.leroymerlin.fr/produits/1m-de-cremaillere-nylon-renforcee-acier-fixation-haute-somfy-91174993.html&quot; rel=&quot;nofollow&quot;&gt;https://www.leroymerlin.fr/produits/1m-de-cremaillere-nyl...&lt;/a&gt;&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 20 May 2025 09:55:12 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102657</link>
  <source url="https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102657" />
  <guid>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102657</guid>
  <fb20:id>9102657</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Ces crémaillères ne sont plus fabriquées.&lt;/p&gt;&lt;p&gt;La crémaillère a cassé parce que l&amp;#39;écart pignon/ crémaillère était totalement déréglé.&lt;br /&gt;La masse du portail était supportée sur la crémaillère.&lt;br /&gt;En général dans cette situation c&amp;#39;est l&amp;#39;arbre du moteur qui casse.&lt;/p&gt;&lt;p&gt;En fonction de l&amp;#39;âge du système il faudra tout changer.&lt;/p&gt;&lt;p&gt;Bonne journée à vous&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 20 May 2025 08:18:24 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102485</link>
  <source url="https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102485" />
  <guid>https://forum.somfy.fr/questions/3599001-compatibilite-cremaillere-somfy-freevia-280-300/answers/9102485</guid>
  <fb20:id>9102485</fb20:id>
