    <title>[Forum Somfy] Suivi de la question: Tahoma Switch login issue, after upgrade to latest version</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F3623769" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: Tahoma Switch login issue, after upgrade to latest version</description>
    <pubDate>Wed, 30 Jul 2025 14:43:58 GMT</pubDate>
    <lastBuildDate>Wed, 30 Jul 2025 14:43:58 GMT</lastBuildDate>
  <title>Réponse de Dejan V.</title>
  <dc:creator>Dejan V.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello.&lt;/p&gt;&lt;p&gt;official answer, from whom?&lt;/p&gt;&lt;ul&gt;&lt;li&gt;Germany can&amp;#39;t help&lt;/li&gt;&lt;li&gt;Croatia doesn&amp;#39;t want to help&lt;/li&gt;&lt;/ul&gt;&lt;p&gt;And  I can&amp;#39;t use your device or change the scenes.&lt;/p&gt;&lt;p&gt;Plus, the device hasn&amp;#39;t worked since the last upgrade and as far as I&amp;#39;ve heard, I&amp;#39;m not an isolated case.&lt;/p&gt;&lt;p&gt;I expected at least your understanding, because all other support has failed.&lt;/p&gt;&lt;p&gt;The username and password are good, as I can still see the device in HomeAssistant.&lt;/p&gt;&lt;p&gt;I have tested several IOS devices, the same on all of them&lt;/p&gt;&lt;p&gt;Thanks, Dejan.&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/3623769-tahoma-switch-login-issue-after-upgrade-to-latest-version/answers/9161585</link>
  <source url="https://forum.somfy.fr/questions/3623769-tahoma-switch-login-issue-after-upgrade-to-latest-version/answers/9161585" />
  <guid>https://forum.somfy.fr/questions/3623769-tahoma-switch-login-issue-after-upgrade-to-latest-version/answers/9161585</guid>
  <fb20:id>9161585</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/20231645</fb20:author-profile>
  <fb20:question-id>3623769</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;/p&gt;&lt;p&gt;I would like to ask for help.&lt;/p&gt;&lt;p&gt;After the latest upgrade of the Tahoma Switch device, login is no longer possible (IOS device).&lt;br /&gt;I contacted Somfy Slovenia, where I bought the device, and they forwarded the data to Somfy Germany, which refused to help, saying that the device is registered in Croatia.&lt;br /&gt;Somfy Croatia, however, refused to help because the device was not installed by their service providers.&lt;br /&gt;Don&amp;#39;t get me wrong, I chose Croatia, which is very close to me, and Slovenia is not on the list.&lt;br /&gt;Now, I can wipe my nose because I trusted the Croatians.&lt;br /&gt;As good as Tahoma Switch is, I can&amp;#39;t speak for the support in my case.&lt;br /&gt;If I can&amp;#39;t log in, how will I upgrade the device next time so that it works again?&lt;/p&gt;&lt;p&gt;I think you are my last hope, so I ask for your understanding.&lt;/p&gt;&lt;p&gt;The device PIN is 2006-7362-4330.&lt;/p&gt;&lt;p&gt;Thanks and best regards, Dejan.&lt;/p&gt;&lt;p&gt;Merci,&lt;/p&gt;&lt;/div&gt;
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello&lt;/p&gt;&lt;p&gt;Since the device is certainly not known to French servers, I don&amp;#39;t think French customer service can help you. However, please wait for an official response.&lt;/p&gt;&lt;p&gt;Have a nice day!&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 30 Jul 2025 08:57:23 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3623769-tahoma-switch-login-issue-after-upgrade-to-latest-version/answers/9160865</link>
  <source url="https://forum.somfy.fr/questions/3623769-tahoma-switch-login-issue-after-upgrade-to-latest-version/answers/9160865" />
  <guid>https://forum.somfy.fr/questions/3623769-tahoma-switch-login-issue-after-upgrade-to-latest-version/answers/9160865</guid>
  <fb20:id>9160865</fb20:id>
