    <title>[Forum Somfy] Suivi de la question: unregister account</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F3648725" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: unregister account</description>
    <pubDate>Fri, 23 Oct 2026 07:12:15 GMT</pubDate>
    <lastBuildDate>Fri, 23 Oct 2026 07:12:15 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Sean,&lt;br /&gt;I don&amp;#39;t have acces to UK somfy server. &lt;br /&gt;You have to contact somfy UK about that.&lt;br /&gt;Have a nice day.&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9518909</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9518909" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9518909</guid>
  <fb20:id>9518909</fb20:id>
  <fb20:question-id>3648725</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;/p&gt;&lt;p&gt;Nicolas F. a fait une réponse à la question &amp;quot;Could you please remove a used Tahoma Switch from another account?&amp;quot;: PIN: 2075-79160902&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de Sean M.</title>
  <dc:creator>Sean M.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hello, I’ve I’ve inherited a Somfy Tahoma Switch which is registered to someone else’s account (person is now deceased).&lt;br /&gt;Could I please have the Switch unregistered so I can connect my new blinds.&lt;br /&gt;I’m in the U.K.&lt;br /&gt;Switch PIN is: 2051-4635-9126&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 22 Oct 2026 07:34:38 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9518145</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9518145" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9518145</guid>
  <enclosure length="2430958" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/6b27354ded1499aa/image_original.jpg?bb28c87" type="image/jpeg" />
  <fb20:id>9518145</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/21773901</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Rafael,&lt;br /&gt;Je vous invite a refaire l&amp;#39;activation de votre Tahoma.&lt;br /&gt;Bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 10 Aug 2026 07:28:58 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9469723</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9469723" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9469723</guid>
  <fb20:id>9469723</fb20:id>
  <title>Réponse de Rafael A.</title>
  <dc:creator>Rafael A.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Nicolas,&lt;/p&gt;&lt;p&gt;Merci pour votre aide. Comme demandé, je vous joins une photo de ma TaHoma Switch.&lt;/p&gt;&lt;p&gt;Cordialement,&lt;br /&gt;Rafael&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 07 Aug 2026 12:45:30 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9468969</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9468969" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9468969</guid>
  <enclosure length="1879293" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/20c57a1bed2a7ea3/20260804_091340_original.jpg?bb28c87" type="image/jpeg" />
  <fb20:id>9468969</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/20114989</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Rafael,&lt;br /&gt;Pouvez vous me faire une photo de l&amp;#39;etiquette sous la tahoma &lt;br /&gt;car le code pin ne semble pas correspondre&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 04 Aug 2026 07:19:04 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9466375</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9466375" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9466375</guid>
  <fb20:id>9466375</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;/p&gt;&lt;p&gt;Je rencontre toujours un problème de connexion avec ma TaHoma Switch.&lt;/p&gt;&lt;p&gt;Lorsque je me connecte à l’application avec l’adresse e-mail et le mot de passe du client, l’écran reste indéfiniment sur le message « Log in in progress… » et la connexion ne se termine jamais.&lt;/p&gt;&lt;p&gt;J’ai testé une autre compte client sur le même téléphone, avec la même application et le même réseau Internet, et cette autre compte fonctionne normalement. Le problème semble donc être lié à cette compte ou à l’association de la TaHoma avec les serveurs Somfy.&lt;/p&gt;&lt;p&gt;Pourriez-vous, s’il vous plaît, effectuer une réinitialisation complète de cette TaHoma Switch, la remettre aux paramètres d’usine et réinitialiser son association côté serveur afin que je puisse recommencer toute la procédure d’installation ?&lt;/p&gt;&lt;p&gt;Modèle : TaHoma Switch NA&lt;br /&gt;PIN : 2075-0741-4910&lt;/p&gt;&lt;p&gt;La TaHoma est actuellement alimentée et connectée au réseau par câble Ethernet.&lt;/p&gt;&lt;p&gt;Merci d’avance pour votre aide.&lt;/p&gt;&lt;p&gt;Cordialement,&lt;br /&gt;Rafael Abbas&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 03 Aug 2026 14:41:47 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9466011</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9466011" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9466011</guid>
  <fb20:id>9466011</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Hi Saša,&lt;br /&gt;you can already re-activate this tahoma.&lt;br /&gt;Have a nice day.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 03 Aug 2026 08:27:20 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9465513</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9465513" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9465513</guid>
  <fb20:id>9465513</fb20:id>
  <title>Réponse de Saša D.</title>
  <dc:creator>Saša D.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Good morning,&lt;/p&gt;&lt;p&gt;Could you please remove a used Tahoma Switch from another account? PIN: 2309-2430-6314.&lt;/p&gt;&lt;p&gt;thanks a lot &lt;/p&gt;&lt;p&gt;best regards&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 03 Aug 2026 06:03:57 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9465275</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9465275" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9465275</guid>
  <fb20:id>9465275</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/21734331</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Rafael,&lt;/p&gt;&lt;p&gt;Je ne peux pas réinitialiser votre box car elle n’est associée à aucun compte.&lt;/p&gt;&lt;p&gt;Afin de pouvoir poursuivre, j’aurai besoin d’informations concernant votre compte Somfy.&lt;/p&gt;&lt;p&gt;À ce titre, je vous contacte en privé.&lt;/p&gt;&lt;p&gt;Bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 10 Oct 2025 14:08:20 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9222035</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9222035" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9222035</guid>
  <fb20:id>9222035</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Nicolas,&lt;/p&gt;&lt;p&gt;Merci pour votre réponse.&lt;/p&gt;&lt;p&gt;J’ai refait la procédure comme demandé, mais le problème persiste.&lt;/p&gt;&lt;p&gt;Je supprime bien la box de mon compte, mais lorsque j’essaie de l’ajouter à un nouveau compte, le système indique que cette box TaHoma est déjà associée à un autre compte.&lt;/p&gt;&lt;p&gt;Pourriez-vous, s’il vous plaît, la réinitialiser complètement afin qu’elle puisse être enregistrée à nouveau ?&lt;/p&gt;&lt;p&gt;PIN : 2075-7916-0902&lt;/p&gt;&lt;p&gt;Merci beaucoup pour votre aide.&lt;/p&gt;&lt;p&gt;Cordialement,&lt;br /&gt;Rafael A.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 10 Oct 2025 13:11:16 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9221947</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9221947" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9221947</guid>
  <fb20:id>9221947</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Rafael,&lt;/p&gt;&lt;p&gt;Je vous laisse réessayer s&amp;#39;il vous plait.&lt;/p&gt;&lt;p&gt;Bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Fri, 10 Oct 2025 12:14:31 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9221839</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9221839" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9221839</guid>
  <fb20:id>9221839</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Jacky,&lt;/p&gt;&lt;p&gt;Merci pour votre retour.&lt;/p&gt;&lt;p&gt;Je vous renvoie le PIN de la box : 2075-7916-0902, et je joins également une photo de l’arrière du gateway où le PIN est visible.&lt;/p&gt;&lt;p&gt;Cette box n’est plus associée à mon compte, mais elle ne permet toujours pas d’être enregistrée sur un nouveau compte.&lt;/p&gt;&lt;p&gt;Vous pouvez la réinitialiser complètement sans problème.&lt;/p&gt;&lt;p&gt;Merci beaucoup pour votre aide.&lt;/p&gt;&lt;p&gt;Cordialement,&lt;br /&gt;Rafael A.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 09 Oct 2025 23:01:48 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9220959</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9220959" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9220959</guid>
  <enclosure length="1882204" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/e7153e574eb86dad/20251007_163411_original.jpg?bb28c87" type="image/jpeg" />
  <fb20:id>9220959</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Rafael,&lt;/p&gt;&lt;p&gt;Je ne trouve pas de box associée à ce PIN.&lt;/p&gt;&lt;p&gt;Bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 09 Oct 2025 13:49:55 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9220595</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9220595" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9220595</guid>
  <fb20:id>9220595</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Jacky,&lt;/p&gt;&lt;p&gt;Je suis le vendeur actuel de cette box TaHoma. Je l’ai achetée neuve, et maintenant je la transmets à une autre personne.&lt;/p&gt;&lt;p&gt;J’ai déjà essayé toutes les procédures possibles pour supprimer l’appareil de mon compte, aussi bien sur le site que dans l’application, mais cela ne fonctionne pas.&lt;/p&gt;&lt;p&gt;Le problème vient du système Somfy : même après le changement de compte, la box reste associée à l’ancien compte au lieu d’être complètement réinitialisée.&lt;/p&gt;&lt;p&gt;Pourriez-vous, s’il vous plaît, réinitialiser manuellement la box et retirer toute association afin qu’elle puisse être enregistrée par le nouveau propriétaire ?&lt;/p&gt;&lt;p&gt;PIN de la box : 2075-7916-0902&lt;/p&gt;&lt;p&gt;Merci beaucoup pour votre aide.&lt;/p&gt;&lt;p&gt;Cordialement,&lt;br /&gt;Rafael A.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 08 Oct 2025 18:51:59 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9219647</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9219647" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9219647</guid>
  <fb20:id>9219647</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;C&amp;#39;est manipulation est a faire avec le compte rattaché à la box.&lt;/p&gt;&lt;p&gt;Si ce n&amp;#39;est pas votre compte il faut attendre la prise en charge par un Yello qui doit contacter le propriétaire du compte rattaché.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 08 Oct 2025 12:26:41 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9219195</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9219195" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9219195</guid>
  <fb20:id>9219195</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Jacky,&lt;/p&gt;&lt;p&gt;Merci pour votre réponse.&lt;/p&gt;&lt;p&gt;J’ai déjà effectué cette procédure à la fois depuis l’application et depuis le site web, mais lorsque j’essaie d’ajouter une nouvelle compte, le système indique que cette box TaHoma est déjà associée à un autre compte.&lt;/p&gt;&lt;p&gt;Pourriez-vous, s’il vous plaît, la désassocier manuellement afin que je puisse l’enregistrer à nouveau ?&lt;/p&gt;&lt;p&gt;Merci d’avance pour votre aide.&lt;/p&gt;&lt;p&gt;Cordialement,&lt;br /&gt;Rafael A.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 08 Oct 2025 11:51:16 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9219155</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9219155" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9219155</guid>
  <fb20:id>9219155</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour&lt;br /&gt;C&amp;#39;est a l&amp;#39;ancien propriétaire d&amp;#39;appliquer cette procédure&lt;br /&gt;&lt;a href=&quot;https://www.somfy.fr/assistance/faq?question=comment-reinitialiser-ma-box-si-je-veux-la-vendre&quot; rel=&quot;nofollow&quot;&gt;https://www.somfy.fr/assistance/faq?question=comment-rein...&lt;/a&gt;&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 08 Oct 2025 08:15:04 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9218737</link>
  <source url="https://forum.somfy.fr/questions/3648725-unregister-account/answers/9218737" />
  <guid>https://forum.somfy.fr/questions/3648725-unregister-account/answers/9218737</guid>
  <fb20:id>9218737</fb20:id>
