    <title>[Forum Somfy] Suivi de la question: migration vers switch ?</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F3728491" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: migration vers switch ?</description>
    <pubDate>Tue, 19 May 2026 14:18:04 GMT</pubDate>
    <lastBuildDate>Tue, 19 May 2026 14:18:04 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Cédric,&lt;br /&gt;Je vous confirme avoir fais le necessaire.&lt;br /&gt;bonne journée&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9415331</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9415331" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9415331</guid>
  <fb20:id>9415331</fb20:id>
  <fb20:author-avatar>https://dimelo-users-production.s3-eu-west-1.amazonaws.com/identity_avatars/4b443c8bf1273e1e/avatar_normal.png?ae1f036</fb20:author-avatar>
  <fb20:question-id>3728491</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;br /&gt;merci de transferer la clé de la V2 vers la switch. pour info, les 2 tahoma sont branchées.&lt;br /&gt;TAHOMA V2: 1213-6180-6746&lt;br /&gt;SWITCH :        2321-7906-5794&lt;br /&gt;dans la mesure du possible, je souhaiterais conserver l&amp;#39;adresse gmail.&lt;br /&gt;merci d&amp;#39;avance&lt;/p&gt;&lt;p&gt;Merci,&lt;/p&gt;&lt;/div&gt;
  <title>Réponse de cedric C.</title>
  <dc:creator>cedric C.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;C&amp;#39;est fait&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 18 May 2026 09:27:34 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9413651</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9413651" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9413651</guid>
  <fb20:id>9413651</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/14552955</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Cedric,&lt;br /&gt;pouvez vous appuyer sur le bouton prog sous la tahoma pendant 2 sec puis revenir vers moi.&lt;br /&gt;Bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 18 May 2026 09:07:52 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9413603</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9413603" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9413603</guid>
  <fb20:id>9413603</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Erreur sur le pin de la switch : Switch : 2321-6838-4285&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 13 May 2026 09:25:29 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410895</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410895" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410895</guid>
  <fb20:id>9410895</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Cedric,&lt;/p&gt;&lt;p&gt;Je ne trouve aucune box activée avec ce code PIN , pouvez vous le vérifier ?&lt;/p&gt;&lt;p&gt;Bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 13 May 2026 09:06:26 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410847</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410847" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410847</guid>
  <fb20:id>9410847</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;J&amp;#39;ai activer la switch avec un autre compte normalement vous devriez la voir ?&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 13 May 2026 06:21:39 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410621</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410621" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410621</guid>
  <fb20:id>9410621</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Cédric,&lt;/p&gt;&lt;p&gt;Pouvez vous activer la Tahoma Switch afin que je puisse faire le transfert de la clé IO ? &lt;/p&gt;&lt;p&gt;Bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 12 May 2026 15:05:51 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410379</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410379" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9410379</guid>
  <fb20:id>9410379</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour, &lt;br /&gt;je voudrais migré un V1 vers la switch :&lt;br /&gt;Pin de la V1 : 0204-2773-9941&lt;br /&gt;Switch : 2321-6638-4285&lt;/p&gt;&lt;p&gt;Dans l&amp;#39;espoir de ne plus avoir de perte de programmation régulière de mes moteur IO...&lt;/p&gt;&lt;p&gt;Merci d&amp;#39;avance&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 11 May 2026 07:26:53 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9408783</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9408783" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9408783</guid>
  <fb20:id>9408783</fb20:id>
  <title>Réponse de thierry S.</title>
  <dc:creator>thierry S.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour&lt;br /&gt;merci tout apparait bien et fonctionne bien dans l’application&lt;br /&gt;mais la switch apparait en connexion filaire alors qu&amp;#39;elle est branchée en wifi.&lt;br /&gt;encore merci&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 06 May 2026 14:02:07 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9406733</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9406733" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9406733</guid>
  <fb20:id>9406733</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/13775661</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Thierry,&lt;br /&gt;Je vous confirme avoir fais le transfert de votre connexoon a votre Tahoma j&amp;#39;ai transferer également le compte.&lt;br /&gt;bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 06 May 2026 13:48:31 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9406717</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9406717" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9406717</guid>
  <fb20:id>9406717</fb20:id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Yonel,&lt;br /&gt;Les Yellows ne sont pas constament sur le forum et vient en fonction de leur temps libre.&lt;br /&gt;Toutefois je vois que vous avez reussi a avoir le transfert de vos equipements IO.&lt;br /&gt;bonne journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Wed, 06 May 2026 13:45:21 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9406707</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9406707" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9406707</guid>
  <fb20:id>9406707</fb20:id>
  <title>Réponse de yonel T.</title>
  <dc:creator>yonel T.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour,&lt;br /&gt;Ce serait sympa si un yellow pouvait de ma migration vers Switch &lt;br /&gt;Merci d&amp;#39;avance&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 04 May 2026 18:06:24 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9404643</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9404643" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9404643</guid>
  <fb20:id>9404643</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/8085239</fb20:author-profile>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour&lt;br /&gt;J ai une box connexoon ( code pin :0816-2769-1581) ou tou mes volets sont connectés.&lt;br /&gt;Serait il possible de migrer ma configuration sur une tahoma switch ( code pin 2303-2258-8392) que je viens d &amp;#39;acheté ?&lt;br /&gt;Je n aurais pas besoin de reconfigurer mes volets ?&lt;br /&gt;merci&lt;/p&gt;&lt;/div&gt;
  <pubDate>Mon, 04 May 2026 15:43:24 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9404549</link>
  <source url="https://forum.somfy.fr/questions/3728491-migration-switch/answers/9404549" />
  <guid>https://forum.somfy.fr/questions/3728491-migration-switch/answers/9404549</guid>
  <fb20:id>9404549</fb20:id>
