    <title>[Forum Somfy] Suivi de la question: montage contact de porte</title>
    <atom:link type="application/rss+xml" href="https%3A%2F%2Fforum.somfy.fr%2Fxml%2Fquestions%2F738833" rel="self"/>
    <description>[Forum Somfy] Suivi de la question: montage contact de porte</description>
    <pubDate>Fri, 22 Aug 2014 13:57:59 GMT</pubDate>
    <lastBuildDate>Fri, 22 Aug 2014 13:57:59 GMT</lastBuildDate>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Pour un montage sur des portes epaisses, tu peux remplacer l&amp;#39;aimant fournit par un de ton choix. &lt;/p&gt;&lt;p&gt;fixer le DO sur le chambranle et coller un aimant sur l’épaisseur de la porte. &lt;/p&gt;&lt;p&gt;(une photo sera plus parlante)&lt;/p&gt;&lt;p&gt;fonctionne aussi pour les velux&lt;/p&gt;&lt;/div&gt;
  <link>https://forum.somfy.fr/questions/738833-montage-contact-porte/answers/1560983</link>
  <source url="https://forum.somfy.fr/questions/738833-montage-contact-porte/answers/1560983" />
  <guid>https://forum.somfy.fr/questions/738833-montage-contact-porte/answers/1560983</guid>
  <enclosure length="120933" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/324a63111d434e14/dscn5110_original.jpg?c6832e6" type="image/jpeg" />
<enclosure length="126379" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/f041323a69a2c150/dscn5112_original.jpg?c6832e6" type="image/jpeg" />
<enclosure length="198102" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/cdecefbe8a0ca265/do_velux_original.jpg?c6832e6" type="image/jpeg" />
<enclosure length="197656" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/fc027b9bd50bd7e3/do_velux1_original.jpg?c6832e6" type="image/jpeg" />
<enclosure length="182532" url="https://dimelo-answers-production.s3.eu-west-1.amazonaws.com/177/8bfca125e8a99002/do_velux2_original.jpg?c6832e6" type="image/jpeg" />
  <fb20:id>1560983</fb20:id>
  <fb20:question-id>738833</fb20:question-id>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;ma porte d&amp;#39;entrée est épaisse et je n&amp;#39;ai pas suffisamment de cale plastique pour mon contact de porte soit bien aligné. Peut on monter les contacts de portes en sens inverse?&lt;/p&gt;&lt;/div&gt;
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Bonjour Jean-François,&lt;/p&gt;&lt;p&gt;Je vous invite fortement à monter des cales supplémentaires plutôt que d’intervertir les éléments. Comme indiqué dans la notice il faut éviter de placer la partie active sur l&amp;#39;ouvrant car il sera sujet à des vibrations et verra donc sa durée de vie réduite.&lt;/p&gt;&lt;p&gt;Bonne Journée&lt;/p&gt;&lt;/div&gt;
  <pubDate>Thu, 21 Aug 2014 15:31:41 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/738833-montage-contact-porte/answers/1559650</link>
  <source url="https://forum.somfy.fr/questions/738833-montage-contact-porte/answers/1559650" />
  <guid>https://forum.somfy.fr/questions/738833-montage-contact-porte/answers/1559650</guid>
  <fb20:id>1559650</fb20:id>
  <title>Réponse de Hubert L.</title>
  <dc:creator>Hubert L.</dc:creator>
          &lt;div class=&quot;body-bd&quot;&gt;&lt;p&gt;Outre l&amp;#39;aspect esthétique, je ne suis pas expert mais je pense que oui.&lt;br /&gt;Cependant, il est facile de confectionner une cale d&amp;#39;épaisseur dans un morceau de bois pour aligner le détecteur d&amp;#39;ouverture de porte et son aimant (je l&amp;#39;ai fait avec une cale de 2cm).&lt;br /&gt;D&amp;#39;autre part j&amp;#39;ai constaté que le détecteur et son aimant supportaient facilement 1cm d&amp;#39;écart entre le plan de la porte et celui du bâti. La détection d&amp;#39;ouverture de la porte se produit à environ 4 cm de distance. Faites des essais vous verrez mais ne réglez pas l&amp;#39;écart de manière à être &amp;quot;limite&amp;quot;, cela pourrait entraîner de fausses alarmes si l&amp;#39;huisserie bouge avec le temps, si la porte se déforme ou si elle ferme avec du jeu.&lt;/p&gt;&lt;/div&gt;
  <pubDate>Tue, 19 Aug 2014 15:38:37 GMT</pubDate>
  <link>https://forum.somfy.fr/questions/738833-montage-contact-porte/answers/1556871</link>
  <source url="https://forum.somfy.fr/questions/738833-montage-contact-porte/answers/1556871" />
  <guid>https://forum.somfy.fr/questions/738833-montage-contact-porte/answers/1556871</guid>
  <fb20:id>1556871</fb20:id>
  <fb20:author-profile>https://forum.somfy.fr/users/6122710</fb20:author-profile>
