Dear!
I have received a few times in last two weeks an error message on my Tahoma Pad (1.0.17) that the new software is available but that Pad was not able to install it...
Dear Robert,
My Tahoma Pad was already for some time 1.0.17.0. It is now (few weeks ago) started to report that "Update Failed". And again this morning there was a red...
Dear!
Dear Robert,
Thanks for the answer. I have already installed Tahoma pad software for the PC 1.0.17.0 and it reports that there is no new software available. But Tahoma Pad...
Dear All Tahoma Pad IO users!
I want to hear your wishes for future versions of Tahoma Pad. I have already expressed few wishes and also recognized some from you. Maybe with...
Dear All!
I'm curious if there is still some roadmap for TahomaPad? The software for BOX is continuously developping while there was no update for nearly 1 year for the Pad...
Hi!
Not many new features added at all:
Version=1.0.17.0
Description=The following features are now available:
WiFi connection, Automatic date and time (nice)...
peut on utiliser le micro-récepteur d'éclairage avec un interrupteur et une télécommande? Je m'explique, est ce que je peux allumer mon éclairage avec un interrupteur...
Sylvain!
What kind of switch is it? Can you post a link, please?
Is it possible to use your wiring diagram also if I use two "standard" switches to manually control light...
Dear Somfy Team!
I have one more which should not be too complex to solve. It would be nice if I could set a scenario with Sunrise/Sunset with some offset. For example, I...
1. Tahoma pad + Sunis WireFree: I wish to have more than 1 sun level for creating scenarios. Eg. at first level shutters are lowered half, when sun reaches level 2 then shutters...
Je voulais savoir si une station météo existait et compatible via la tahoma? Car cela pourrait être pas mal.
Par exemple :
La station capte que la pluie commence à...
Hi All!
It would be very nice to have a meteo station compatible with Tahoma/Tahoma Pad io. It could be a simple sensor for at least indoor and outdoor temperature, humidity...
